04-11-2016, 09:15 AM | #85 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Got them from Lowes in Hardware section in the cabinets you could probably get by using 7/8 length
Orange Krush II
04-11-2016, 09:44 AM | #86 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Even better that I can pick them up locally, thanks!
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
05-19-2016, 01:37 PM | #87 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
Tagged for reference
05-19-2016, 09:36 PM | #88 |
Drives: 17 C7 GS WGG Join Date: May 2015
Nice! Curious to hear if you notice any change in high speed corners and if the added weight is a benefit...
05-20-2016, 10:35 AM | #89 |
Weight
You'd be lucky if it weighs 5-10lbs more so to the low side...
Orange Krush II
06-17-2016, 08:36 AM | #90 |
Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
So something occurred to me. When I normally jack up the front end I use one of the cross members on the sub frame that will be covered up by the pan.
I would raise it there and then put jack stands under the pinch welds. With the pan I can't do that anymore... What are you guys doing?
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
06-17-2016, 11:44 AM | #91 | |
RAMPS
Orange Krush II
06-17-2016, 12:33 PM | #92 |
Drives: '14 1LE Join Date: Nov 2013
06-17-2016, 12:37 PM | #93 |
I was thinking that. Kind of wanted to avoid buying ramps. This damn car is so low that none of the regular ramps clear. I'll ended up having to buy race ramps with the extensions and what not. It'll be a bunch of cash.
06-17-2016, 12:53 PM | #94 | |
Drives: 2013 2SS (sold) Join Date: Jan 2016
Similar to this but only 2 blocks tall and not nearly this intense lol https://i.ytimg.com/vi/BjgKMkzIhU4/maxresdefault.jpg
Track Parts/Stock Parts Part Out http://www.camaro5.com/forums/showthread.php?t=515534
06-17-2016, 12:56 PM | #95 | |
06-17-2016, 01:04 PM | #96 | |
Mine are just like this, but the top landing is only about 8" long and my ramp slope is much shallower http://www.e46fanatics.com/members/tim330i/poly/1.jpg
06-17-2016, 01:05 PM | #97 | |
06-17-2016, 04:15 PM | #98 | |
Ramps
Mine are very similar in construction but much longer and 4 or 5 boards tall.
Orange Krush II
Thread Tools | |
