08-28-2012, 10:01 PM | #1 |
Drives: 2011 1LT RS M6 Black Join Date: Jul 2010
Hydrolocked Or So I Thought
So today i managed to avoid all the puddles in Charleston, SC during an absolute downpour however there was one that i simply COULD NOT avoid… no other road to my condo. It seemed shallow at first but it was DEEP…
So my car shuts off. And I have an Injen CAI. So i pushed the car to a dry area and try and crank it up. NOTHING. Had the car towed to my house about an hour away and took off the silicone connector between the CAI and the throttle body and water POURED out. So i removed all the spark plugs and turned it over a few times until water stopped shooting out of the cylinders. I dried everything off the best i could and put all the spark plugs back in and after about 5 minutes that LLT was singing again!! Changed the oil and flushed a few extra quarts through for good measure. Drove the car about 25 miles without any issues so far. At about 500 miles i will change the oil again just to make sure. Any other suggestions? |
08-28-2012, 11:24 PM | #2 |
[COTW 4/13/15]
Drives: Supercharged LLT Join Date: Jul 2010
Wow that's pretty scary, maybe just check that nothing else is damp like electrical and etc. sorry that happened :(
08-28-2012, 11:44 PM | #3 |
Voodoo Medicine Man
Drives: Black 2SS with RS package Join Date: Jul 2010
that, my friend, is a hydrolocked engine.....
I'd be listening for any unusual noises as hydrolocking an engine can do a lot of internal damage to the metal parts... maybe you got off lucky and nothing got bent
08-29-2012, 01:15 AM | #4 |
You got lucky as hell sir!
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/ |
08-29-2012, 01:41 AM | #5 | ||
I know i have horseshoes up my ass! |
08-29-2012, 01:49 AM | #6 |
Drives: 2010 Camaro 2LT V6 Join Date: Jul 2009
Do you have a hydro shield installed on your intake? Also, how did you go through the puddle, fast or slow? Just curious, in case I have to deal with a big puddle.
Injen CAI, V-Max Throttle Body, Rx 25mm Iceolator, Rx 10mm Plenum Spacer, Mace Ported Manifold, ARK N-II Catback, Trifecta Tune, Rx Catch Can.
BMR Bushing Inserts,Pedders Radius Rod Inserts, Pfadt Sway Bars and Endlinks, LSR Front Subframe Brace SS Brembo Brakes, Racing Brake Stainless Lines |
08-29-2012, 07:24 AM | #7 | |
My Dream Car
Drives: 2011 SIM LS3 1SS Join Date: Jul 2009
I say take the car in to get checked, my freind did that to his car, he let it dry out and drove for about 6 months, after that the engine blew. Reason, bent rod, reason, from hydrolocking. What would have cost a third of the cost to fix cost him a remanufactured engine. over all cost was about 3k on a used mazda 3 engine with warrenty. I would think the camaro engine is going to be more. good luck
CAI intake/ADM Scoop/Stainless Power Headers/Dynatech cat back exhaust/Vitesse Throttle Control/ Ported Throttle Body/QTP Electric Cutouts/ 3.91 gears and janetty rear posi/ Tuned by Janetty racing
09-03-2012, 10:01 PM | #8 | ||
the warranty on these cars is to 36k right? |
09-03-2012, 10:13 PM | #9 |
I would check the hydroshield, I replaced my intake after having some problems with water, when I checked the hydroshield water went right through. Had mine installed for almost two years. Like anything I think the water repellent feature may wear off, may want to treat it with a water repellent product.
09-04-2012, 08:28 AM | #10 |
anything new
09-04-2012, 08:29 AM | #11 |
I dont think it was unless you had the throttle wide open to get enough water inside. it probably just stalled out.
09-04-2012, 08:52 AM | #12 | |
i mean water shot out of the heads when i cranked the engine with the spark plugs out.... |
09-04-2012, 09:00 AM | #13 |
INJACC
Drives: 2010 CGM 2LT/RS AUTO Join Date: Jan 2009
100,000 Miles - 6 Years Power Train
Member of 'Club Elite' #70
2LT/RS Auto / Solo HFC / Solo Mach X-LLT J-Pipe / JBA Headers Shorty CAI - Cold Air Inductions / VMAX TB / Trifecta Tune Hotchkis Max Strut Brace / Blade Dovetail Spoiler / Elite Catch Can ACS T3 Hood Ports / T2 Bumper Ports / T2 Splitter / ACS T1 Led Light Kit ACS Rockers / ACS Composite Hood Liner / ACS Upper Rear Quarter Ports ACS Front Wheel Mud Flaps / ACS Rear Wheel Mud Flaps / Vitesse Throttle Controller Pedders Drop Suspension / BMR Lower Control Arms / Style 41 ZL1 Wheels / Oracle Afterburners / Oracle Concept SMD Side markers Complete SS Brembo Brakes Set |
09-04-2012, 09:03 AM | #14 |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
Before taking it in to the dealer if you find problems you better put the factory air box back on. Just a suggestion.
The Bird is the word! |
Thread Tools | |
