![]() Drives: 2018 1SS 1LE M6 Join Date: Jul 2013
problem reseting tpms
so I put my summer tires on over the weekend and when I was all done I went to got start the re learn process and when I did the first tire nothing happened.... I sat there let air out and kept deflating the tire and no horn beep or anything kept retrying it and soon enough I had to start putting air back into the tire cause I let so much out. has anyone had this problem before?
![]() Drives: 2010 2SS/RS Join Date: Jul 2014
Thought that only worked on 2010 ans 2011? Have you set them that way on this car before?
Current car
2011 Backdraft RT3 427 stroker (DART block/ forged internals/ AFR 205 Aluminum heads/ Quickfuel 750) 600hp/590ftlbs, wilwood brakes, custom JRI double adjustable shocks. Weighs in at 2300 lbs.... Use to have 2010 Camaro SS - ECS SC 1500, Kooks LTH + HFC, Corsa, CTS-V brakes, Detroit Speed Coilovers, BMR sways (FE4 conversion), DSE endlinks, BMR toe rods and trailing arms, Forgestar F14's |
no I have never done it before when I got my winter set of rims/tires I brought it to a shop and they used the tool they had to do it. I went to the dic and pressed the set/clear on the tpms screen and it said relearning activated so I started with driver side front wheel. so if this only works on a 2010-11 how do we get it to work on 2013s?
ok nevermind just figured it out 2013s NEED the tool to reset and that's it u cant do it the way I am trying. guess I need to stop by chevy or my mechanic to reset them....
Thread Tools | |
