11-02-2015, 10:47 AM | #1 |
Drives: 2011 Camaro SS Join Date: Apr 2015
GI: Solid Roller 427 LSx built for lots of nitrous!!
I am just gauging interest for my 427 LSx solid roller long block. This engine was built to take a lot of nitrous. Built by Borowski. Everything is brand new. I do not need to sell but I am thinking of selling my 2011 Camaro SS (If anyone is interested in a 7k mile roller with cage, fuel system, build rear, full interior PM me also) and moving into a different project. I do not need to sell but if the right offer comes along I will.
Long Block Break Down: -GMPP LSx block punched to a 427ci 12.5:1 Compression -K1 Technologies Crankshaft Shaftech Balance Crankshaft to 1850 BW, Counterweights, Magna Flux Insp, Check TIR -Diamond Custom Dome Piston, Int Mill Maxi-Lite, Offset Pins, Pin Fit, Dbl Pin Oilers, Inboard Forging, H-13 Piston Pin .927D, Support Rails -Callies Ultra H-Beam Rod SBC 6.000 2.100 -Clevite H-Series Rod Bearing - Standard Size, TM-77, Chevy, Small Block -Clevite H-Series Main Bearings -Cloyes Hex-A-Just Timing Set - Hex-A-Just, Single Roller, Billet -Steel Sprockets, Chevy, 6.0L, Set -Melling Performance Oil Pump - Standard-Volume, Chevy, 4.8/5.3/5.7/6.0L, Each -ARP Cam Bolt Kit - High Performance, Black Oxide, M8, Chevy, 5.7L, LS1,Setof3 -ARP Balancer Bolt Kit - Chromemoly, Black Oxide, 12-Point, Chevy, 4.8, 5.3, 6.0L, LS1, LS6, Each -Fel-Pro Conversion Set Gasket - Chevy, 4.8, 5.3, 5.7, 6.0L, Set -Total Seal Piston Rings -COMP Cams Custom Ground Camshaft Core - Camshaft, Custom Grind, Race Roller Tappet, Chevy, Small Block, LS1, -Durabond Cam Bearings - LSX -Crower Shaft Mount Rocker Arms -GMPP-DR CNC Ported heads 6-bolt heads -PAC Racing Springs Dual Spring 400 Series Retainer - Titanium -LS retainer for PAC-1530, 1335 Valve Springs. Lock angle: mini 8 -PAC Valve Springs - DUAL SPRING 1.300 OD, 1.800, .800 LIFT -PAC Racing Springs Steel Spring Seats (0.060 Thickness) -PAC Racing Springs Steel Valve Locks - Mini 8 degree - Radius -Groove - +0.050 Install Height -Isky Red Zone Solid Mechanical Link Bar Lifters - Needleless -Bronze Bushings, EZ Max -Chevrolet Performance Valley Cover Gasket To build this motor cost me roughly 21-22k (I only have the price as 22k for the ad). As stated everything is brand new. Please no tire kickers. If you have serious questions about it please let me know. Motor was built to go high 7s low 8s and street use. |
01-04-2016, 12:30 AM | #2 |
No one wants a 7 second capable motor?
01-05-2016, 02:07 PM | #3 |
Drives: 416 w/TH400 Join Date: Mar 2012
what do you call Lots of nitrous
ERL 416 - 12.5 cr, TH400, Custom VVT Cam, PRC 255 heads, NW 102 TB, Aeromotive stealth fuel system, Fast 102 plumbed with a nitrous express direct port kit, BMR 15" conversion kit
01-05-2016, 11:25 PM | #4 |
For my setup it is going to be a 500 shot.
01-18-2016, 11:57 PM | #5 |
bump..
01-19-2016, 06:21 AM | #6 |
Svt lol
Drives: 2011 ss inferno orange blown Join Date: Jan 2012
Curious to know if you want to sell just the fuel system?
01-20-2016, 12:59 AM | #7 |
PM replied.
03-19-2016, 12:59 PM | #8 |
I am not "Fast & Furious"
Drives: 2010 Camaro LSX454 1LE Join Date: Nov 2008
Any chance you would just sell the heads? Thanks.
The day I take a bend too fast
Judgement that could be my last I'll be wiped right off the slate Don't wait up 'cause I'll be late, I'll be late |
Thread Tools | |
