01-07-2016, 02:25 PM | #1 |
Drives: 2016 2ss Join Date: Aug 2015
Low speed clutch rattle
I'm not sure if it's the clutch or not but when going really slow, maybe 5mph then pressing the clutch, there is a metallic rattle coming from somewhere. I'm not sure when I will take it in but I will soon.
01-07-2016, 02:53 PM | #2 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
Could be a little clutch chatter.
01-08-2016, 02:40 AM | #3 |
Drives: 2018 ZL1 1LE Join Date: Jul 2009
I have the same thing on mine but it is pretty consistent and doesn't sound like anything is hurting.
Curious if this is normal. I think I remember my 5th gen doing the same thing. |
01-08-2016, 08:20 AM | #4 |
Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ! Join Date: Sep 2015
Yes I have noticed this but feels like more of a common situation with clutches and low speed disengagements. At least for me it is only when you depress the clutch.
01-08-2016, 11:04 AM | #5 |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
Does anyone know if the flywheel is single mass or dual mass on the Gen 6? In the C4 (Vette) with the ZF tranny, a switch from a dual mass flywheel to a single mass flywheel would result in horrible chatter that sounded like your engine was literally falling apart when at idle and with the clutch engaged and in neutral. It could be the same but to a letter extent in the gen 6.
01-16-2016, 06:27 AM | #6 | |
01-16-2016, 09:50 AM | #7 | |
Drives: 2016 Camaro 2SS Join Date: Dec 2015
01-19-2016, 06:43 PM | #8 |
Drives: 16 Camaro SS Join Date: Nov 2015
I have this low RPM rattle as well on my A8.
it sounds like change in a can or something like that. its consistent. Any ideas? |
02-08-2016, 02:54 AM | #9 |
Drives: 2016 1SS Yellow Join Date: Aug 2015
I just took my car and noticed the same thing.. I thought I am ****ing up... like when the car starts moving in 1st gear... and then I want to move into 2nd....I press the clutch all the way in...and the sounds there... like its screeching... once I let go off the clutch its fine... :(
1SS,Yellow,Gray Wheels,Black bow ties,NPP.
02-24-2016, 12:41 PM | #10 |
Drives: My work van for now Join Date: May 2010
It's the throwout bearing. Perfectly normal.
02-24-2016, 03:24 PM | #11 |
Drives: 2014 2LS (traded in) 2015 1SS 1LE Join Date: Apr 2015
I see GM is still putting junk clutches in the Camaro. Mine sounds like some one throwing a box of hammers down the stairs. Was told it's "normal". Have they at least fixed how jerky and temperamental it is?
02-24-2016, 04:07 PM | #12 |
Banned
Drives: 17 SuperSport Camaro 6 on the Flo' Join Date: Feb 2016
A lot of cars have clutch rattle, not just GM.
02-25-2016, 03:16 PM | #13 |
I've driven several imports with MT as well as a couple offerings by Dodge and Ford and have never heard such a clunking rattling hot mess as I have in this Camaro. It's really the only thing I don't like about the car.
05-03-2016, 09:47 PM | #14 |
Drives: 2016 SS M6, NPP Join Date: Apr 2016
From 1st to 2nd you can hear noises.. I think it's normal, dealer said it's normal so what gives.
Thread Tools | |
