![]() Drives: 2010 Camaro 2SS Join Date: Mar 2020
What tires do you run on your SS?
My car: 2010 2SS, 20" rims with 245/45/20 front and 275/40/20 rear.
The car still has its original Pirelli P Zero tires and they are in bad shape. What do all of you replace your original Pirelli's with? New Pirelli's or something comparable or better? I've been looking at General Tires, G-Max RS front and rear. Proper heat range, load ratio, are ZR tires, etc. The General Tires have a higher tread wear rating. Pirelli's are something like 220 and General are in mid 300 range, I believe. So this probably tells me that the Pirelli's are softer rubber than the General's? Do any of you run these General Tires? Or stick to original Pirelli's, or something else? Thanks for any insight! |
![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
Nitto 555G2
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
Tri-County Camaro SWFL
MP4S
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
For better or worse (that’ll get some opinions) I have ‘re-tired’ once and went Pirelli Nero’s on the rear and original P-zero’s up front. Had a flat two weeks ago and had to use that bullshit system in the trunk but...observed two things. The front P zeros are not run-flat but did a great job of saving my MRR wheel even though it was completely deflated. The tire was shot but the goo and pump got me home. But I was close when it happened.
So, if you want to maintain original performance, go with P Zero. But you will pay for the privilege. : /
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Continent ExtremeD06 available on tire rack.
#6 |
I should point out that I had to replace the rears first. Just bought the front P zeros. Imagine that!
#7 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
Summer- Front...... BF Goodrich Sport Comp-2 summer tire 275's
Rear........ Nitto 555R Extreme Drag 305's Mounted on chrome Z-28 replicas Winter- Front......General G-max 245's Rear......General G-max 275's Mounted on original factory wheels
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
#8 |
![]() ![]() Drives: 2014 2SS/RS Join Date: Jan 2018
I run P zeros. 275 up front. 305 out back. They are soft. Milage wear is fast but they sure do grab above 45 degrees.
2014 2SS/RS LS3/M6
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
since I only have the lowly V6, no Power like those v8's, I run the Bridgestone Duelers hp
275 40 20 up front and 315 35 20's on back also they are run flats so don't have to worry about Flats
Hot Wheels Emblems and Floor Mats, Morimoto Fog Lights, PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting & My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller & Paddle Shifter Heritage Grill, Manual Shifter Boot, CNC Throttle Body, Trifecta Tune, Trunk Black out and Side Grills, Hot Wheels door Sills.
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
Firestone Firehawk Indy 500 - 245/45/20 front and 275/40/20 rear.
#11 |
Started#gottalovethatblue
I previously had some Continental Extreme DWS tires that did well. I recently put some Firestone Firehawk Indy 500's on and they're nice so far. Don't hook up too well on a cammed SS if launching from first, but it could be that I only have a couple hundred miles on them so far and they need to still break in.
#12 |
![]() ![]() Drives: 2011 Camaro SS Join Date: Jul 2019
Nitto 555r 305s drag radials out back. Falken Aziens 255s on the front. I have the matching Falken Aziens in 295s for the rear in the basement.
#13 |
![]() Drives: 2014 1ss camaro Join Date: Jul 2017
I run square 275/40/20 with yokohama s-drives on the street great for rain and 300 tread wear. American racing 922 9 inch wide 10 mm offset
#14 |
Drives: 2010 Camaro 1SS LS3 Join Date: Jan 2015
Stock, Pirellis...
Then went with Firestone Firehawk Indy 500 - 245/45/20 front and 275/40/20 rears. Nice Tires! Then got me some wider tires after I bought my wheels with Nitto NT05 - 275's up front, 315 for rears. Then went with Nitto NT555 G2's - same size as the NT05's - after the NT05's gave me a bit of a scare in the rain. I wanted a better looking tire, with better treading and the Tire Gods answered my prayers. These tires run about 250 each and they've been great on my end... even in the rain. With the NT05's I could start feeling hydroplaning on a med/light rain above 60mph. With the NT555 G2's no hydroplaning, even above 80mph. I'm on my second set of NT555 G2's. I will get a 3rd set. Here's a good shot of them; Last edited by Spec; 06-18-2020 at 10:16 PM. |
Thread Tools | |
