02-23-2022, 01:57 PM | #1 |
Drives: 2010 IOM 2ss/RS Join Date: Sep 2009
fic1200 for lsa fit ls3?
wondering if a set for a ctsv (lsa) will fit my ls3 without issues.
Turbonetics running 8lbs boost at 700rwhp tuned by Hi Rev, installed by K&M w/cat-muffler delete, ACS splitter, Fesler GFX, MPD1 spoiler, Custom painted Rally stripes, Cordon CR1 wheels 275/315s, Hotchkiss comp sways and end links, Barton shifter
02-24-2022, 03:50 AM | #2 |
Drives: Ashen grey, 1SS, L99 Join Date: Aug 2016
Yes sir, LS9, LSA, and LS3 injectors are interchangeable as far as I know. LS3 are 42#s for sure, LSA is 56#S and LS9s are 62#s I believe. I understand you’re getting FIC 1200s, but my point is I have LSA injectors out of a CTSV in my SS right now, so I’m pretty confident I’m right and that all are interchangeable on these platforms.
Roto-fab CAI, Nick Williams 102mm TB, LOD X1 V3 intake manifold, GMPP LS3 heads, Night Fury cam, TSP 2” long tubes, Corsa ZL-1 catback, Nitrous Outlet 102mm plate kit/150 shot, NGK BR7EF plugs with Taylor plug wires, DSX flex fuel kit, ZL-1 fuel pump and injectors, B&M deep trans pan, Yank 3400 converter, 3.45s with BMR Delrin bushings, mishimoto 169° Thermostat, GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, ZL1 10 spoke wheels, 12” subwoofer, and custom paint matched interior.
03-07-2022, 08:49 PM | #3 |
Drives: 2014 1ss camaro Join Date: Jul 2017
interesting would you happen to know the part numbers for the LS9 and the LSA ?
Thread Tools | |
