03-13-2024, 02:54 PM | #1 |
Drives: Chevrolet Camaro Join Date: Mar 2020
PLEASE HELP IS IT MY BCM???
Hello everyone,
My 2012 Camaro ss the high mount brake light stopped working so I bought a new one went through everything to replace it. Plugged it up and still no high mount brake light. What could it be there is not a fuse for it or the other brake lights. I read that the bcm operates it so I checked all the fuses for the bcm 1-8 and all the fuses are ok. PLEASE HELP I don't know what to do!!!! Thanks
03-13-2024, 03:49 PM | #2 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
Bad BCM, broken wiring, bad ground, bad light socket are all possible and probably a few more. Bad BCM is probably the least likely. Going to take some diagnostic testing to determine what is actually the issue.
03-13-2024, 05:43 PM | #3 |
Drives: 2013 ZL1 Join Date: Sep 2021
Try disconnecting your battery and shorting your cables together.
03-14-2024, 04:31 PM | #4 |
Drives: 2011 2SS, 2006 GMC Sierra Join Date: Jul 2019
Check fuse F33 (20A) in the underhood fuse block. Check for power on the White wire at the high mount connector and ground on the Black.
Thread Tools | |
