02-16-2020, 12:57 PM | #141 |
Drives: 2020 SS 1LE Join Date: Jan 2020
carguy55 what rotors are those front and rear? Looks great btw.
02-16-2020, 01:01 PM | #142 |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
02-16-2020, 01:13 PM | #143 |
02-16-2020, 01:33 PM | #144 | |
02-16-2020, 02:09 PM | #145 |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
I'm Jealous!!!!
NPP, MRC, Tinted side & rear reflectors, OEM ZL1 Rockers / 3rd Brake / Darken tail lights, OEM Blk rear splash guards, Satin hood wrap, Fuse pull, Sound tube delete, Cat delete, Ported 95 TB, Ported MSD IM, Dry RotoFab, ARH 1 7/8 headers, E85, "Performance Dyno" Tune, BMR "pieces", "Track" alignment, Hawk DCT-70/70's w/SRF, Goodridge lines, Ti shims, Red powdered calipers, 18" APEX SM-10's w/ Pirelli DH's, FE4 Vert swaybars, Brake cooling ducts, ATI 10% UD, Vorshlag camber plates, OEM 1LE Splitter w/APR Ext., Velossa BIG MOUTH Ram Air, CF QA1, ZLE brakes(F)
02-17-2020, 08:26 PM | #146 |
Drives: Honda S2000 Join Date: May 2019
I have my 19 in set up pretty dialed in so thought I'd share.
Using 5mm spacers up front with Silverado extended lug nuts, -2.9 deg camber front, did wire tuck in left rear, (no rubbing on fender liner anyway) 19x10 et23 305/30/19 19x11 et43 325/30/19 Goodyear s3 tires 220 tw so I can run BS AUTOX (4th raw time, 3rd pax out of 80+ cars at first autox with this set up) Liking it a lot so far. Eric |
02-23-2020, 06:23 PM | #147 |
Drives: 2018 SS 1LE Hyperblue Join Date: Jul 2017
To you guys running ARP studs, can you still use the stock lug nuts on the stock wheels? I got a set of Forgestar CF10s for autoX and can only get about 5-6 turns on the lugs. If I go long studs, will I need open ended lugs?
02-23-2020, 06:57 PM | #148 | |
Drives: 2017 SS 1LE Join Date: Jan 2018
02-23-2020, 07:12 PM | #149 |
Drives: 22 1SS 1LE Summit White Join Date: Sep 2016
likewise!
#53 F Street
2022 Sponsor autocrossdigits.com Autocrossing Videos https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag Instagram: apexit_53 2022 Rapid Blue 1SS 1LE 2019 D Street national champion (2019 civic Type R) |
02-23-2020, 07:18 PM | #150 | |
ARP studs #100-7736 (1/2" longer) Gorilla 45148BC-20 - 3/4" hex long lug closed nuts work on track wheels and stock. Stock lugs are too short but you could run a spacer I suppose or try trimming the tip of studs. https://www.camaro6.com/forums/showt...=513759&page=3 |
02-23-2020, 07:23 PM | #151 |
do they make oe length arp studs? I don't like the extended ones!
#53 F Street
02-23-2020, 07:30 PM | #152 |
02-23-2020, 07:40 PM | #153 |
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold) Join Date: Nov 2016
May I ask where you found the Stoptech rear rotors that are compatible with Gen 6 SS 1LE? Do you have some information on the weight, part numbers?
02-23-2020, 09:01 PM | #154 |
I use a 3mm spacer. extended studs not really needed but I like the idea of stronger ones!
#53 F Street
