02-10-2016, 08:10 PM | #141 |
Drives: Mopars Join Date: Mar 2014
02-10-2016, 08:20 PM | #142 | |
Drives: '16 C7 Z51 Join Date: May 2012
Long story short, GM has over-complicated this, and I would just do 122 lb.ft regardless of what year your car is, if I were you.
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD) '13 Mazda MX-5 Club (Build Thread) '17 RAM 1500 Crew Cab 4x4 Night Edition '15 Nissan Rogue S AWD |
02-10-2016, 08:45 PM | #143 |
Ok couldn't find my tag so here it goes...
2015 ZL1 rotors 1771146 $322 1771145 $322 2015 corvette supercharged 1722670 $429 1722669 $410 J56 brakes J6F red 1711040 oem brake pads the good ones $239. 2014 camaro ss rears 1771051 rear rotors 97 each 1710882 rear oem pads $79 ISO good ridge brake lines and 3 bottles of motul 600 $211 shipped Caliper bolts $24 for front and rear I used a 5% discount code at rock auto found online. Total $211 JDP shipped $1955 Rock Auto shipped $24 Rogers Chevy shipped $2180 for new fronts and new rear rotors lines and pads Subtract $263 if rears not needed. Love this site. Mike |
02-14-2016, 07:39 PM | #144 |
Account SNAFU
Drives: 13 Tahoe 79 Scout II 15 1LE Join Date: Sep 2008
posting for reference
02-28-2016, 07:37 PM | #145 | |
Drives: 2013 2SS 1LE NPP GBE Join Date: Sep 2012
02-28-2016, 08:09 PM | #146 | |
Drives: 2013 Camaro 1LE Join Date: Jul 2012
See the thread here related to this post I made last fall. I also list the part numbers I ordered for the calipers as well as the other supporting parts part numbers. http://www.camaro5.com/forums/showpo...27&postcount=3
02-28-2016, 08:40 PM | #147 |
My 1LE is getting a better brake upgrade
Yes, I was asking if these would work on a 2013. By your link I see now the answer is YES. Thank you.
I had also created this matrix and current pricing from multiple sources, but have several questions (see matrix / or below in this thread): CALIPERS (1) Are these calipers 6 piston? Photos look like 4 piston on GM Parts Direct and I AM GM Parts. (2) Do the calipers come with dust boots? (3) What is the caliper bolt (front) P/N? I assume the stock SS bolts are OUT ?? (4) Is the TTY 30lbs + 90d __or__ 44lbs + 90d ?? Saw 44lbs + 90d above. (5) Any concern running these with the stock rear calipers and rotors? (6) Part 22833923 for 2013 Camaro V8 w/o Supercharger and W/performance package are $968.36 ea. Is that right!? Why are the corvette calipers so much less? (7) do the calipers come with the pistons? BRAKE LINE (1)I’ve already put Goodridge braided SS brake lines on my 1LE. Can they be reused? (2) If the answer to (1) is “no”, what is the actual Goodridge part number that can be used? Thank you all in advance! --CRT REF: online spreadsheet My online BOM. Last edited by CrystalRedTintcoat; 02-29-2016 at 12:19 AM. |
02-28-2016, 10:05 PM | #148 | |
02-29-2016, 04:28 PM | #149 |
Hi guys ... Can someone look at my grid and questions? I totally appreciate any input you may have.
02-29-2016, 04:39 PM | #150 | |
2013 Camaro SS1LECTSVZ28
Drives: 2013 AGM 1SS/1LE Join Date: Nov 2012
02-29-2016, 04:48 PM | #151 |
Dropspeed, you rock! Thanks so much. I'm ready to go shopping!
03-03-2016, 12:28 PM | #152 |
Well, I went shopping. No turning back now. Wish me luck, gents. Again, thank you!
03-03-2016, 12:46 PM | #153 |
Post some pics once you have it installed! The worst part is disconnecting brake lines and then having to bleed them all. All the bolt on stuff goes pretty quick actually.
03-03-2016, 01:11 PM | #154 |
New brakes are always fun fun fun : )
