#155 |
INTSAGRAM: Failwish
Drives: 2019 /2SS LT1 Join Date: Jun 2015
I have thre reverse cam on mylink on radio. Just curious of ot will use factory installed cam on aftermarket setup
#156 |
![]() Drives: '11 SGM 1LT/RS, '02 SOM Firehawk Join Date: Jan 2014
See post #1.
Yippee38
#157 | |
pac-kit
Ram...EVERYTHING you need for installation is in the KIT...if you change or add something,,,then you need to find it and pay seperate. if you want to add front camera to grille,,you need to buy a camera and wires. |
#158 |
INTSAGRAM: Failwish
Post #95 is an option... Im just tryn to understand..if its supposed to be with the kit all post leading to that state its missing..some got it and others didn't.
#159 | |
chime module
#160 |
![]() Drives: 2015 2LS Join Date: Mar 2016
Has anyone run into the hazard lights flashing and will not turn off even when disconnecting the bcm plug from the PACS panel? Also pressing the hazard button does not feel like a normal tactile feel of a switch.
#161 |
Found out installer was not paying attention and plugged in bcm cable to PACS module first. Probably blew bcm would be my guess.
#162 | |
![]() ![]() ![]() ![]() Drives: 2011 Camaro 2SS/RS Join Date: Oct 2013
If you had a blown or bad BCM, you wouldn't be able to drive the car.
#163 |
Homeless Life Chose Me
Drives: LS3 (sold 4/21) Join Date: Nov 2014
I may sound like a retard but what exactly is the point of changing out the faceplate and radio? What is the upgrade other than a touch screen. I hear people say better quality or whatever but I don't understand this mod.
Pity a man in familiar places, who yet feels like a stranger.
#164 |
You said it right there. Better quality in every way possible.
#165 |
Plus Nav and iPhone apps
#166 |
Car runs but sound shop still has everything disassembled and 4 way flashers will not turn off even with everything disconnected associated with the PACS kit
#167 |
I thought bcm had nothing to do with drivetrain and engine working. I thought bcm was more lighting controls and sensors
#168 |
which could have one internal circuit shorted on a transistor output and not affect other circuits
