Old 01-06-2016, 08:16 PM   #15
HardrockSS
Drive Fast Take Chances
HardrockSS's Avatar
Drives: 2012 45th anniversary SS
I hear you. I got 3.91 with G-force 1000hp and aluminum driveshaft. Just want to stop the vibration
2012 45th Ls3 M6:ECS 1500, Custom Cam ,Alky Meth kit, Mcleod Rxt, MGW shifter,Pfadt Tri-y headers Solo Mach X, 20%tint,3.91 gears ,Suspension upgrades, G-force axles.700 RWHP
http://www.slowhawkperformance.com/
HardrockSS is offline   Reply With Quote
Old 01-06-2016, 08:30 PM   #16
RankSS
Drives: 2010 Camaro SS
When does the vibration happen? Clutch in and out? Speed related or RPM?
I really don't thing the axle is the issue. My old setup did the same wobble but caused no ill effects other than the seal weeped slightly.
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
RankSS is offline   Reply With Quote
Old 01-06-2016, 08:32 PM   #17
HardrockSS
HardrockSS's Avatar
The vibration happens when the car is under a load. Generally over 40 mph. Push the clutch in or let off the gas vibration goes away.
Old 01-06-2016, 08:38 PM   #18
RankSS
That does sound like driveshaft or axle. Exhaust shake?
Old 01-06-2016, 08:43 PM   #19
HardrockSS
HardrockSS's Avatar
No exhaust does not shake. I put a wrench on every nut and bolt under there the other day. Replaced the OE driveshaft with 1 piece aluminum from Dynatech. Tires balanced and alignment done.
Old 01-06-2016, 09:01 PM   #20
RankSS
Down to the axles then. Put the originals on see what happens.
Old 01-06-2016, 09:07 PM   #21
HardrockSS
HardrockSS's Avatar
I snapped my passenger side that's why I replaced them.
Old 01-06-2016, 10:24 PM   #22
RankSS
Shouldn't be too hard to find another stocker.
Old 01-07-2016, 12:48 PM   #23
Driveshaftshop
Driveshaftshop's Avatar
Drives: own more cars than i can list
I would try this also or if you want to pull the part i can give you dimensions on what the Stock part measures so you can check. may also want to measure the inside of the diff while your measuring.
Driveshaftshop is offline   Reply With Quote
Old 01-07-2016, 02:16 PM   #24
HardrockSS
HardrockSS's Avatar
Ok thanks
Old 01-17-2016, 05:05 PM   #25
GFORCE1320
Drives: 05 GTO
Since these are our axles we would be glad to help. Give us a call and we can tell you what they should measure or if you want just send them in and we can go over all the critical dimensions to see if its something with the stubs.
GFORCE1320 is offline   Reply With Quote
Old 01-17-2016, 05:08 PM   #26
HardrockSS
HardrockSS's Avatar
We exchanged emails about this, I haven't gotten around to removing them yet. Thank you. Also do you think it might be the differential bearings?
Old 01-17-2016, 05:26 PM   #27
GFORCE1320
Drives: 05 GTO
I wouldnt think it would be the bearings.
How about you send the axles in and we can inspect them just to make sure the inner stubs are to spec or maybe a cv joint needs rebuilt.
Old 01-17-2016, 05:27 PM   #28
HardrockSS
HardrockSS's Avatar
Should I just send the one side that has up and down movement or both
