01-09-2023, 10:17 AM | #15 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
Here my Thread on alignment, We were able to get the specs until I added non Adjustable BMR LCA in the rear. I then had to get a BMR Kit for the rear and still were not able to get exactly what I wanted but close.
https://www.camaro5.com/forums/showthread.php?t=596730
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
01-09-2023, 11:04 AM | #16 | |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
My '14 1LE (FE6) was dropped on Z/28 DSSVs (FEA) and I had an aggressive track alignment. Stock, these cars can obtain about -2* up front, and if the strut to knuckle slots on the strut are further elongated, -2.5* is obtainable. If you increase the caster, that reduces the camber potential. I never had to use any other strut bolt other than OE to meet my moderate camber goals. When I wanted to push the envelope for the track I installed camber plates. But for the street, these are unnecessary. I would occasionally set my camber plates to OE position and even with additional caster, I got what I wanted. Out back, when a moderate front street setup of -1.0* to -1.25* camber is used, shoot for about -.5 to -.75* at the rear. No sense pushing the rear camber too high for a street car. So with these goals, the OE arms and eccentric bolts will have zero trouble obtaining that. As I mentioned, honing in on the rear goals is a dance. And from the feedback here on the forums over the years, many shops have neither the patience or know how to do it. BMR will gladly sell you more parts in order to solve an issue that really isn't there. While I had DSE adjustable toe rods on my '14, this was done because it eliminated one of the eccentric bolts and it made adjusting toe way easier. At my still relatively moderate rear track specs, I was not in need of aftermarket parts to obtain my desired #s. Shoot for zero toe up front, minimum .20* toe in (toe in #s are positive) at the rear. Do not go below the .20* otherwise the rear of the car may be unstable, especially with big power. All this is with the assumption that nothing is bent or loose, but any skilled tech should be looking for such deficiencies. Don't be satisfied when the alignment is "in the green", lol. Look at the actual #s. Side to side symmetry, especially with the toe, is the goal and any competent tech can obtain this in a reasonable time.
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
01-09-2023, 11:11 AM | #17 | |
01-09-2023, 11:12 AM | #18 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
Here is Justice Pete's last alignment sheet that he posted.
There are typo's in the stock setting columns. https://www.camaro5.com/forums/showp...52&postcount=2 |
01-09-2023, 11:15 AM | #19 |
One other factor that I would hope a shop has correct in all this is that where the car sits on the alignment rack, the tires should be sitting on "toe plates" These plates laterally slide against each other so when adjustments are made the tire and suspension is not bound up. If the tires are not sitting on toe plates, then adjusting the alignment is going to be difficult. The #s will move erratically making it hard to hone in on tight, solid specs. I mentioned the timing of the bushings. If this is not resolved, this can also cause erratic results, creating a nightmare for the tech. The devil's in the details.
01-09-2023, 11:23 AM | #20 | |
This one is correct: The FE4 and FE5 cross camber is terrible. Tighten that up to .2* max just like the other specs. Same goes for the cross toe but shoot for .05* max cross toe. I shoot for zero cross camber and toe. Ultimately you want the thrust to be zero. That goes a long way to making the car drive super nice.
01-09-2023, 11:40 AM | #21 |
Cdb, the non adjustable BMR LCA are made for a lowered car, I am lowered 1" but it wasn't enough for what the arms are meant for so I could not get the spec, there are others that had the same issue. I was able to get the spec with all the other Mods but the LCA.
01-09-2023, 11:40 AM | #22 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
Thanks for all the info you guys are awesome. NTB does use toe plates and when I checked the camber with my level, I checked it in my garage in the same spot. Thanks cdb95z28 for all that you've given me some things to think about for sure.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
