#15 |
Retired Navy
Drives: 2010 2SS/RS Join Date: Mar 2011
See post below
#16 | ||
Retired Navy
#17 |
![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro SS/RS LS3 Join Date: Aug 2010
I used the Mobil 1 and whatever slip additive they had at O'Reily's. Haven't had any issues.
Yeah, I'll get around to it...
#18 |
![]() Drives: Red LT1 & Silver LS3 Join Date: Feb 2010
#19 |
![]() Drives: 2010 Camaro 1LT RS Join Date: Oct 2009
Royal Purple Max Gear in rear diff and manual transmission...no issues.
#20 |
Slow Turtle
How many differentials have you seen on here that failed because they wore out due to material wear (friction) or had seized bearings? I haven't seen one.
If your gears were destroyed (from almost anything), it damn sure wasn't because of what lube you had in it, unless you think oil film magically stops you from shearing tooth off a ring gear... jokes. |
#21 |
I changed my differential fluid today. I put Royal Purple 75-90 in using a pump. It should have been a 15 minute job but I think Magilla Gorilla tightened the top plug. I had the car up on ramps so I was unable to put a lot of heft to it. Finally I tied a rope onto the ratchet handle and pulled from the back of the car. Once I got past that, the job was cake. After I finished, I took it over to a near by shopping center and did eight figure eights.
It amazes me how much the dealers charge to do that job. No wonder they want you to wait in the waiting room instead of watching what little effort it takes! |
#22 |
![]() Drives: 2010 camaro 2ss/rs..m6..CGM Join Date: Apr 2011
I can get some valvoline gear oil for free...it says its for limited slips...I might go ahead and change it...I've been holding off for some amsoil or redline....but free fluid is tough to beat
-Lethal Racing NF cam
-Kooks LT's/high flow cats -Borla ATAK catback -CAI cold air intake (black)/Apex scoop -LSR shifter -Rick Crawford intake manifold -Monster level 3 clutch |
#23 |
![]() Drives: 2011 2SS/RS ord 7-7-10 home8-24-10 Join Date: Jul 2010
I was shocked how much metal came out of my diff at 600 miles. GM fluid already has the additive so don't spend extra. At 2000 miles I drained off just enough to see what the oil looked like and NO metal. I use AMSOIL Severe Gear and a bottle of GM modifier. Other Camaros I see come through the shop still show metal on the plug so we recommend AMSOIL.
#24 |
![]() Drives: 2013 Camaro ZL1 bone stock 9K miles Join Date: Oct 2010
GM synthetic axle lube
I just bought the GM GL-5 synthetic gear lube part #88900401. I also bought the GM additive part 88900330 Price: $35.08 list $26.31 net price for the lube, additive price is $12.54 list price, $4.98 net. I read about a test of all the top gear lubricants and there is better products, but I heard no complaints with the GM diff lube.
I'll most likely be using Amsoil or whatever DSS reccomends for there HammerHead differential kit when I install it. I broke A right axle an was thinking about buying the 1400hp axles (I think they come with the kit-DSS HammerHead), but I thought about it for a while. I'd rather replace a $182.00 (net price) GM axle an have that break then having gears ($800.00+) or a trans break (thousands), when I can change an axle in under an hour anyway without air tools if I'm in another state drag racing, if it breaks again at the track. Untill I strengthen the rest of the drivetrain.
SLP- long tube headers, hi flow cats w/full SLP 3'' PowerFlo exhaust incl/X-pipe, 160 degree stat, SLP Blackwing CAI. Dyno tuned by ECS-407/409RWHP&TQ. BMR- trailing arms w/poly knuckle bushings, toe links, cradle bushings and differential bushings. QA1 rear lower control arms. Hurst short throw shifter, SS- level 4 axles, DSS- aluminum driveshaft, Pfadt- sport 1.5" rear sway-bar. SPOHN 1.25" front sway-bar. Monster LT1-S twin clutch. Prothane motor mounts. Best 1/4 mile so far- 12:70ET @ 112.24 MPH w/ 2.06 second 60'.
SOLD. Last edited by 10 2SS/RS 6M; 03-26-2012 at 11:42 AM. Reason: Fix corrections |
#25 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Exige, Miata, Ghia Join Date: Jun 2011
When I did my rear diff fluid, it seems like the factory fluid is thinner than the Mobil 1 stuff. When I took the top bolt off, the fluid came out with a slight watery consistency. The Mobil1 gear oil was a lot thicker and would run a lot slower. Both are supposed to be 75W90 oil so why is that? It was a VERY noticeable difference in viscosity.
It costs me about $25 to change the diff oil. $12 for the Mobil1 LS 75w90, and $15 for the limited slip additive. I’ll probably be switching to Amsoil the next go around because it’s only 3 bucks more at my parts store. Come to think about it, I should have just picked up Amsoil instead of Mobil1 for the price difference. The dealer wanted $35 for the GM oil….shessssh…. |
#26 |
![]() Drives: 2010 Camaro RS/2SS Join Date: Jan 2010
Changed mine this weekend. Oil was pretty bad after 9000 miles.
1100, Preliminary order accepted (01/30/2010)
6000, Delivered to the customer (02/27/2010) YA, she came that quick! $IMJAYBIRD$ |
#27 |
![]() Drives: 2010 IBM Camaro SS/RS Join Date: Apr 2012
Great video! Thanks for making that!
Do you have one for manual tranny fluid change, too? ![]()
2010 Stock IBM 2SS/RS
5th Gen Suspension -- The Book | JusticePete | Suspension / Brakes / Chassis | 151 | 05-07-2015 05:52 PM |
Pfadt Street/Race Rear Differential Bushings, get more power to the pavement! | Apex Motorsports | Transmission / Driveline | 5 | 08-10-2010 05:49 PM |
Drag Racing Suspension Kits | Info@PeddersUSA.com | Suspension / Chassis / Brakes | 25 | 02-21-2010 08:48 PM |
