04-25-2024, 08:11 AM | #15 |
Coupe Newbie
Drives: '23 CT5-V BW, '21 Corvette HTC Join Date: Jul 2011
Several points to add:
1. As 23_ZL1-Auto mentioned, you have to unbolt the supercharger from the engine to lift it up to replace the PCV diverter. The bolts are torque to yield. You are technically not suppose to reuse these bolts because the threads are stretched. A new set of bolts should be purchased to reattach the supercharger to the engine. 2. You have a 2024 stock ZL1 so I’m guessing you still have a good portion of your warranty remaining. Should your ZL1 have a major engine failure, there’s a very good chance GM will void the warranty if it sees the catch can. Now some may argue that you can remove the catch can prior to service. However, it’s not a simple procedure and you’re going to need a new set of bolts every time. Now it sounds like I’m arguing against a catch can. I’m not. On a modified high HP engine it makes perfect sense. On a stock engine I’m not convinced the effort to install and risk to warranty are worth it. There are a lot of GM DI engines out there with thousands of miles on them with no catch can that still run perfectly fine.
04-25-2024, 08:12 AM | #16 |
Petro-sexual
I believe the blower mounting bolts are TTY. The seals are probably fine (I think there are 5, total).
'20 ZL1 Black "Fury" A10, PDR, Exposed CF Extractor Magnuson Magnum DI TVS2650R // RFBG // Soler 103 // TooHighPSI Port Injection // THPSI Billet Lid // FF // Katech Drop-In // PLM Heat Exchanger // ZLE Cradle bushings // BMR Chassis-Suspension Stuff // aFe Bars // Diode Dynamics LEDs // ACS Composites Guards // CF Dash // Aeroforce // tint // other stuffs |
04-25-2024, 10:40 AM | #17 |
Drives: 2023 ZL1 - Modified All Bolt On's Join Date: Dec 2022
I reused mine a few times and broke one off and had to remove the entire supercharge, hoses coolant etc. to back the broken bolt out. They are not expensive, maybe ok to use them once after first removal. But, I buy new now every time! I agree the seals are probably fine, but the 10 bolts that hold down Supercharger are TTY, so get new ones!
2023 ZL1 Auto - CSP 2" Long Tubes by Stainless Works | Gesi G-Sport High Flow CATs | Stainless Works Legend NPP Axle Back | Roto-Fab Big Gulp | Kong NM103mm | Kong X-Port | Griptech 2.3" Upper | ATI Super Damper w/18% 9.45" Lower | TooHigh PSI Port Injection w/875cc Injectors | Brisk RR14S Plugs | Granatelli Malevolent Coil Packs | Katech Low Profile Billet Valve Covers | Katech Duel Fuel Pump System | MightyMouse Wild 1000HP CC | DSX Flex Fuel Kit | DSX Billet Lid | DMS 2gal Fender Tank | NT555R2's 305/285 | Katech Tuned | Straight E85 = 784rwhp / 678 torque @ 19psi
04-25-2024, 04:34 PM | #18 | ||
Drives: 24 ZL1, 6.2L Denali, 73 SplitBumper Join Date: Jun 2023
This is the reassurance I was looking for. Once my warranty is up I will consider it for sure. Until then, its just exactly that, do I really want to mess with something knowing I am leaving it stock. If i modify, well sure, but stock is it worth the hassle. If you didn't have to remove the super charger I may consider but having to do all that changes my thoughts on it. Quote:
Noted. This is also what I was worried about, its safer insurance just to get new bolts each time. Thanks for the info.
2024 ZL1 Radiant Red / Coupe / M6 / PDR / BCD / Carbon Scoop, Dash, Shifter / Red Seat Belts / Black Lugs
https://cws.gm.com/vs-cws/vehshop/v2...FJ1R60R0111531 |
04-26-2024, 07:00 AM | #19 | |||
Drives: 2010 Camaro Join Date: Nov 2009
If you want to stop nearly all of the oil and other contaminants there is only one that is that effective, the E2-X Ultra system. And it provides full time vacuum suction on the crankcase instead of simply venting pressure once it builds. Nothing else comes close:
Catch Can Comparison Mightymouse vs Elite Engineering Ultra MightyMouse Catch Can vs Elite Engineering Ultra Catch Can, which one catches more oil, which one is better? The Elite catch can is designed by Tracy Lewis P... www.youtube.com And: Elite Engineering E2-X vs Mightymouse Catch Can Shoot Out In this video I compare the Elite Engineering E2-X catch can with the MightyMouse catch can that has the new super centre in it. I want to see which one is better at trapping oil. I also run an APEX catch can during the test to evaluate the catch can design and how effective it is at trapping oil. I conducted the test by running each can for ... www.youtube.com And one more to understand the benefits of a proper full time vacuum crankcase evacuation system: SDPC Tech Tips: Crankcase Vacuum and engine sealing Wanting to gain a bit more power by going with a vacuum pump or dry sump setup? Something as simple as your rear main seal could become headache when diagnos... www.youtube.com Questions? Just ask. We challenge ANY other design to even come close to the effectiveness of our Patented system. Test conducted as in the first video link so all is fair and equal. Sales questions and support? Email us direct at: Sales@EliteEngineeringUSA.com Tech questions and support? Email us direct at: Tech@EliteEngineeringUSA.com |
05-02-2024, 06:25 PM | #20 |
Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
I am giddy, What a stellar product! 1/8 turn quick release a highly engineered quality catch can. This is a game changer in my mind. Going to do the 500 mile garage king lid removal test, to compared it to my current can. No more 50 1/4 turns to unscrew the son of a bitch.
05-07-2024, 07:38 PM | #21 |
Drives: Chevy Camaro ZL1 1LE Join Date: Aug 2023
OK. I am confused. I have a 2023 ZL1 1LE. I have a service tech that only works on high performance Camaros. I asked about installing a Catch Can, he said it is already installed OEM. He showed me. I took pictures. Looked lagit. Any clarification would be appreciated.
Hoses/Tubes look identical which is what is the topic. Electrical wiring / sensors look different. PN on the box looks different. corrected: 12683284 Last edited by DansZL1-1LE; 05-08-2024 at 07:05 AM. Reason: add picture |
05-07-2024, 07:53 PM | #22 | |
05-07-2024, 08:32 PM | #23 |
Hoses/Tubes look identical which is what is the topic. Electrical wiring / sensors look different. PN on the box looks different. I can confirm, but the picture looks like 12683294 or 12383294. Let me know if you want me to confirm. Thanks! Apologies 12683284 Last edited by DansZL1-1LE; 05-07-2024 at 09:24 PM. Reason: picture not added. |
05-07-2024, 09:09 PM | #24 | |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
You'll thank me later
2022 M6 ZLE: Katech Standard Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation Kit
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild Catch Can Coated AR Headers + GESI UHO Cats + V Bands + AWE Touring + Magnaflow Center X + MSD Coils + Banks iDash + JMS Booster ALL the BMR Read End Goodies + BMR Motor Mounts + JRE Terminator Cam Package + Big Gulp + GMS High Flow Crash Bar DMS Front HX + Fender Tank + FIC 30's + APEX SM.10's + TOYO 305/345 R888R's = 770rwhp 815rwtq @E55 13.5psi |
