05-21-2014, 10:39 AM | #15 |
Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
Here's a pic...I'm guessing the '14 Z/28 is still the same with the seat removed....It's only attached in a few places....takes ten minutes to install...
05-21-2014, 10:48 AM | #16 | |
Drives: BAC Mono Join Date: Apr 2013
I spec the wireless (key-fob) "Never-Die" option as well. "Our NEVER-DIE™ system, internal to the battery case, places an unused vehicle battery into 'sleep mode', with a reserve energy preserved sufficient to provide 2 to 3 restarts after the battery is reactivated. We offer various remote-controlled user interfaces to 'wake' the battery up." So I save 30 lbs (the LiON battery weighs approx 10-11 lbs) and never have to worry about my lap timer or data recording system sucking the battery dry because I forgot to turn it off.
2014 Z/28, White
"I wasn't asked to make it cheap...I was asked to make it FAST!" Mark Stielow, the new Z/28. |
05-21-2014, 10:49 AM | #17 | |
Can someone with a Z/28 confirm/deny this is now it looks as well?
2014 Z/28, White
05-21-2014, 10:50 AM | #18 | |
Drives: G5.R Join Date: Sep 2010
$1400 for the DS. they also have aluminum for cheaper but slightly less weight saving. Lots of info out there on 1-piece vs 2-piece DS.. Here is a nice writeupp on CF DS tech http://www.camaro5.com/forums/showthread.php?t=131502 OK man... If your removing the rear seat, you GOTTA lose the trunk mat too!! that thing is like 20 lbs!! |
05-21-2014, 11:00 AM | #19 | |
2014 Z/28, White
05-21-2014, 11:06 AM | #20 |
It's out for sure...lol....as well as the thin felt piece underneath.....I noticed on the Z/28 pics they still have the battery/"spare" cover piece....That could come out on track days, also.....
05-21-2014, 11:14 AM | #21 | |
05-21-2014, 11:22 AM | #22 |
Drives: 2010 ZR1 "Satan" Join Date: Nov 2013
This will feel really odd for me. With the truck, we always had to ADD weight, not remove it. Do you have any idea how brutal loading a truck with 2000lb of sand bags by hand is?
Need some helium anti-ballast balloons.
2002 Z06 "Blue Meanie" 11.36 ET
2003 Z06 in progress 2009 CTS-V "Spooky" 12.36 ET, bone stock at 1600 mi. Rainy day in Sacramento. Sadness. 2010 ZR1 "Satan" no times yet. 2013 Volt SCCA Solo2 #771 HS3. And a bunch of Duramaxes. |
05-21-2014, 11:23 AM | #23 |
Drives: 2013 2SS 6M Join Date: May 2013
lose a few lbs yourself....
Strut tower brace(GM), CAI, Blade Spoiler, ZL1 wheels and tires, Heritage grill, Dual mode exhaust, and thats it, no more..except for the lowering springs..Ok Hotchkis springs were delivered today, thats it..
05-21-2014, 11:27 AM | #24 | |
That's a fact! A month of Soylent should do it eh?
2014 Z/28, White
05-21-2014, 11:44 AM | #25 |
Runs with scissors...
Drives: '14 Z/28s SIM/SW Join Date: Jan 2013
This is my goal, to make up for adding the A/C and extra speakers. Maybe I should just pull the extra speakers so that I only have to lose 20+ pounds instead of 30+???
05-21-2014, 11:49 AM | #26 |
If you are determined, you can make the headers back titanium with SuperTrapps for under $1000, materials and labor, and be lighter than any aftermarket systems, and sound level adjustable. However, removing weight from under the CG point is the lowest priority.
#1 - Wheel Tire weight. This affects acceleration and braking out of proportion to actual weight loss. ie - 1lb acts like 2lb. #2 - Corner weight. Getting mass out of the corners improves handling. #3 - Weight above CG. Lowers CG. #4 - Weight at CG. 1lb=1lb for performance. And last, weight under CG, which is the only weight where 1lb is less. But you must want it.
05-21-2014, 12:27 PM | #27 | |
Drives: Ferrari F430 Spider F1 Azzurro Arge Join Date: Sep 2013
05-21-2014, 12:28 PM | #28 |
You and me both brother. :-(
