09-24-2014, 04:02 PM | #2815 |
Drives: G5.R Join Date: Sep 2010
Hey guys just updated the OP with more pictures of contributing members engine bay. I will keep working on the OP to make it easier to navigate by adding more hyper links to were new members can get info specific to what they are doing on the thread.
Also, please post DIY on how your doing thing as we all get ideas from each other and how we can do things better. If anybody has pictures of their engine bay (Including updated pictures of the existing engine we already have pictures for) and would like to be added to the OP gallery, please post them so U can add them. Now keep up the great work! |
09-24-2014, 05:50 PM | #2816 |
ou mai gad
Drives: SW 2SS x2 Join Date: Feb 2010
You still have a lot to do to earn LCs special path to heaven.
Those bulbasaured pieces look stunning, wonder how you actually came to know the existence of such process.
09-24-2014, 06:26 PM | #2817 | |
Actually Justin was the one who came across that process, so I cant take credit for it |
09-25-2014, 03:17 PM | #2818 | |
Drives: 93GMC sierra stepside/ ctsv3 Join Date: Dec 2011
Sent from my SAMSUNG-SM-N900A using Tapatalk |
09-25-2014, 07:58 PM | #2819 | ||
09-25-2014, 08:12 PM | #2820 |
CF Cooling plate
Hey guys as a token of my appreciation for all the guys that have contributed to this thread I have a special deal on the cooling plate. PM me for special pricing. To qualify, you would have had to post on the this thread before.
09-26-2014, 01:24 PM | #2821 |
How about that crash bar u got in the front, I know the stock one is heavy and I'm looking to lose as much weight as i can
09-26-2014, 02:20 PM | #2822 | |
09-26-2014, 03:18 PM | #2823 |
Sweet! Thanks, I'll give him a call tomorrow morning or today after work if I get out on time. Adding 80lbs to my car with the iron block
09-26-2014, 03:51 PM | #2824 |
Drives: 2009 ZR1 Join Date: May 2010
Just painted this. A stupid bug flew through the spray and was "painted" into it. I removed the carcass and sprayed over the crater left. Now I have a small run you probably won't see unless pointed out.
I used the Eastwood 2K gloss black spray. Bada$$ stuff at $30/can. One can did the entire bay but I put it on thick. I also bought a can of clear gloss 2k. I'm saving it for when I do the rest of the bay - the front and sides where the hood sits. I'll clear the whole bay then. I had a heck of a time getting the bay painted. It was my technique. I was trying to dust instead of paint. I ended up sanding down the passenger side twice to fix the roughness from the paint drying too fast when dusting. The passenger side was my practice side as it was the most uncluttered. Now, let this stuff dry and then I'll sand out the orange peel and put the ABS, Fusebox, and PCM in place along with my custom made enclosure box. I didn't paint all along the firewall because it will be getting covered up by the gray stuff I can't think of what it's called right now... I'll have to buy another can of the Eastwood stuff because I have some cutting to do on the cowl and I'll repaint that whole area so it matches. The Eastwood stuff isn't exactly a match for factory black but it sure looks good there. Who knows, it might be a closer match when dry but I doubt it. |
09-26-2014, 07:12 PM | #2825 |
^ Nice
Im going to do mine when I get all the wires moved and the motor pulled out, Got 2 12oz cans of IOM and 2 cans of Clear. Thinking I might cut some steal and fill in where the abs plugs go through to the wheels, Im going to re route them anyway and it will looks way better without that plastic cover |
09-26-2014, 07:16 PM | #2826 |
I used the ceramic paint. When it dried, it was super smooth to the touch and felt like porcelain. I just wet sanded it to get rid of the orange peel, etc. It dried more black than the pics showed.
I'll get another can and hit it again in a week after rewiping for dust, etc, hit it with a red scotchbrite pad and shoot some more coats. |
09-27-2014, 08:44 AM | #2827 | |
Wow bud! That's a hell of a transformation!!! Looks like your relocation the fuse box, the ABS and the Battery post. Did you smooth the the strut towers also? Its going to look really good when your done, special with the new IW 8 rib front drive a little birdie told me your getting, LOL FYI, you might want to try wet sanding with 400 followed by 600. I re-prep the did the engine bay again. Wet sanding with a little water leaves a really smooth finish. Finally finish cleaning it with a tack rag. |
09-27-2014, 01:22 PM | #2828 |
army life
Drives: 2018 hyper blue zl1 Join Date: Feb 2011
Has anyone removed the ac and left it off since im gonna have to do a complete engine build because one of my lifters failed and exploded and froze one of my lifter bearings to the cam and I cant get it off now removing the engine im going all out nothing like Nathan though but I punchered my ac condenser and decided who needs ac I don't daily drive but the ac condenser has the powersteeing cooler on as well anyone separated the 2 and removed the ac plus im looking for the ac plug or blockoff from the firewall to plug were the lines used to be coming out anyone have any suggestions
Blake also what does your modified cabin air filter cover look like I moved my abs in there as well and may be interested in how u modified thanks guys
Mods: lingenfelter 15% overdrive pulley, ATI balancer, kooks headers, DSX low side aux pump, DSX flex fuel, GPI stage 2 cam, trans tune, cat delete, rear seat delete, rotofab cai
Similar Threads | ||||
Roto-Fab | Engine Covers - S/C | Fuse Relay Cover | Radiator Cover | Billet Oil Cap+ | AutoAgenda | Exterior Parts & Accessories | 14 | 02-06-2013 08:43 PM |
New Texas Speed & Performance Engine Machining Center! | Trevor @ Texas Speed | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 18 | 01-16-2013 03:46 PM |
Hawk Performance Brake Pads part HB247Z.575 $85.00 | Rogan | USA - Florida | 2 | 10-07-2011 12:10 PM |
Acronyms? | KEEP RT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 20 | 03-11-2011 08:57 PM |
Great Read and Info on Oil Weight | Banshee | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 1 | 11-23-2009 09:03 PM |
