04-11-2019, 09:33 PM | #281 | |
Yeah already saving for a clutch at a minimum, but heads will likely make the list too to help drop that boost and keep the temps down.
2015 Camaro ZL1 - 769RWHP 755RWTQ Mods: RPM 5" intake, Kooks 2" headers w/o cats, 9.1" lower, 2.55" upper, Kong performance ported blower/snout, NW 102mm TB, afco hx w/ fans, RPM cam package, ID1050x injectors,160 degree t-stat, Tuned by Fran at RPM
Best 1/4 mile: 10.99@127 Dyno graph YouTube 2003 C5 Z06 - SOLD Mods: 455 RWHP 415RWTQ FBO and FTI Street Sweeper Cam (236/240 .631/.612 111 lsa) |
05-15-2019, 09:00 PM | #282 |
Drives: 2015 M6 ZL1, 2012 silverado Join Date: Apr 2019
2015 M6 ZL1 8k miles
Kooks headers with high flow cats Borla Atak cat back Cold air inductions intake. Tuned by Speed Inc
2015 M6 ZL1 Bright Yellow: Cold Aid Inductions intake, 2.55 Griptec pulley,Kooks headers with high flow cats, Borla Atak cat back, ID1050's, Aux pump, Flex Fuel sensor 635whp 633wtq
08-11-2019, 04:51 PM | #283 |
Drives: camaro Join Date: May 2013
2012 zl1 6 speed manual 2 inch arh headers no cats, 5 inch rpm intake and custom tune 518hp 505tq
1998 Camaro Z28
370 Billet 85mm tfs235 Holley Hi Ram LJMS Cam TH400 PTC 9.5 9inch 3.50 8.87@150 1.21 60ft 17psi Pumpgas 8.46@161 1.23 60ft C16 22psi 2012 Camaro ZL1 6 speed 2 inch arh headers no cats 5inch rpm intake 518hp 505tq |
08-26-2019, 09:11 AM | #284 |
2014 Camaro ZL1 6MT
Drives: 2014 ZL1 Join Date: Mar 2016
Do we have a thread for E85 on the ZL1? I've heard 25-30 rwhp and also 75-100 rwhp with bolt ons. Seems inconsistent...
2013 Camaro 1SS/RS 6MT - SOLD
2014 Camaro ZL1 6MT - 😎 |
08-28-2019, 11:50 AM | #285 |
Drives: 2013 VR ZL1, M6 Join Date: Nov 2017
2013 ZL1 M6, 34k Miles 485whp 526wtq 74 Degrees Ambient Temp, 91% Humidity, Hood Closed, 4th Gear Pull, No Cool Down (30 min drive and put right on the dyno). Only "power mod" is the 63-3079 K&N Intake
#3257 | 485whp 526wtq | K&N 63-3079 | Gates K080660HD (Green Belt) | ACDelco UPF48R | ZL1 Addons Wicker Bill | Mild2Wild
08-28-2019, 12:37 PM | #286 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Looks like you've either got some timing pull, knock retard or AFR richening that started happening around 4300 based on the way the whole curve took a step-shift downwards. Did they happen to do a log?
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // Elite Ultra CC // BMR MM
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
08-28-2019, 01:42 PM | #287 | |
It was super hot and muggy that day, and the car literally was placed on the dyno as soon as I showed up, so it never cooled down. No knock, I have that monitored on my Aeroforce. IAT2's never went above 125-135 either. Now this was an outside dyno event, and it rained that morning. The rollers were wet, and I was the first car on the dyno. I was thinking it could have possibly been due to that. I also made sure traction and stability control were both off, but the dyno operator had to shut the car down while he strapped her down. I asked if he made sure he had the traction button in for 7 sec's vs placing it into PTM. He said yes, but he looked awfully confused when he was pressing the traction button. Question... Does the ZL1 utilize the IAT1's (before the blower), or IAT2's (after the blower) to determine timing retard when temps get hot? I know on my Cobalt SS Supercharged, the IAT2's were the critical temps when it came to timing and power, but I see a lot of members on here only mention IAT's which is not specific. If that's the case, it could be the reason for the dip in my power curve. While IAT2's stayed in the 125-135 range, IAT1's were a good deal higher.
10-09-2019, 02:12 PM | #288 |
Drives: 2013 ZL1 Join Date: Nov 2018
2013 6 speed, 95,000 miles. Was late May in the south when it was on the rollers (hot).
VMax ported throttle body Adjusted boost Bypass valve Cat delete K&N intake No tune 540rwhp and 500 tq SAE on a dynojet Car trapped 121mph in this configuration in June Last edited by FASTFATBOY; 06-11-2020 at 06:19 PM. |
01-03-2020, 01:10 AM | #289 | |
Drives: 2013 ZL1 M6 Join Date: Jun 2017
Sick Numbers mine are similar
2013 M6
Roto Fab CAI - TSP 2"/ Corsa, Pat G Stage 3 custom Cam Nick Williams 102MM, Griptech Pulley (2.45) DSX Aux Lower (9.45) - 1300cc FID Fuel Injectors McLeod RXT 1200 Trunk Tank w/ rule 3700 791/776 E85 YouTube: 3 Honks Away IG: 3 Honks Away |
01-07-2020, 10:50 PM | #290 | |
607whp on Wongs Mustang dyno:
BTR stage 3 cam/.660 springs/BTR PR's 2.50" upper pulley only @12lbs ID850's Speed Engineering 1-7/8 LT's No cats stock NPP Afco HX with fans Roto-fab CAI Last edited by FasNuf; 01-07-2020 at 11:12 PM. |
01-07-2020, 11:09 PM | #291 |
Question...
Does the ZL1 utilize the IAT1's (before the blower), or IAT2's (after the blower) to determine timing retard when temps get hot? I know on my Cobalt SS Supercharged, the IAT2's were the critical temps when it came to timing and power, but I see a lot of members on here only mention IAT's which is not specific. If that's the case, it could be the reason for the dip in my power curve. While IAT2's stayed in the 125-135 range, IAT1's were a good deal higher.[/QUOTE] ....... IAT2's retard timing. The temp at which timing is retarded is determined by your tune and can be modified if you know someone with HPtuners or the like. Care should be taken. Better to reduce IAT2's with a better intercooler and CAI, Icebox and intercooler reservoir will help cool too. If you're in a warm climate, you can reduce the intercooler coolant ratio to be more water and less antifreeze. Some run straight water since it's not shared with the engine coolant it won't boil. |
01-08-2020, 11:43 AM | #292 | |
IAT2's retard timing. The temp at which timing is retarded is determined by your tune and can be modified if you know someone with HPtuners or the like. Care should be taken. Better to reduce IAT2's with a better intercooler and CAI, Icebox and intercooler reservoir will help cool too. If you're in a warm climate, you can reduce the intercooler coolant ratio to be more water and less antifreeze. Some run straight water since it's not shared with the engine coolant it won't boil.[/QUOTE] Thanks for the reply. I had all the cooling mods you mention on my Cobalt SS. After doing further research the step down my graph took was due to the cat protection. As I mentioned in my original dyno post it was a disgusting muggy day when I performed the pulls (74 degrees 91% humidity). The car was strapped down to the dyno with no cool down after a 30 min drive with two back to back pulls (hood closed). During normal data logging on the street, I notice no adverse KR or high IAT2 temps, and the car runs very strong. I'll re-dyno this spring or fall and see how she performs.
04-20-2020, 03:41 PM | #293 |
neko95
Drives: 2017 2SS Join Date: Jun 2009
Auto with 15K miles
'17 2SS
K&N CAI, Borla axle back 69' RS (Sold) 10' RS/SS (Sold) 14' ZL1 M6 (Sold) 14' ZL1 Auto (Sold) |
04-30-2020, 07:18 AM | #294 |
nice numbers neko. What all was done to the car for the 573/586 numbers
