11-14-2014, 05:25 PM | #29 |
That's what I like about the Paxton 1500. I'll run out of engine before I'll run out of blower.
11-15-2014, 05:25 PM | #30 |
whippled 5th gen
im over 700 rwhp, been told to upgrade my engine internals next after upgrading suspension and clutch first.
11-15-2014, 05:36 PM | #31 |
Too much is never enough!
Ive been told that 720 is fine on stock internals. Anything more than that and I'm pushing it. I could add a cam and be ok to get more, but that will have to wait till the next project. Dropping all that cash at once is like getting kicked in the groin. At least it is for me.
Matt and AGP seem to say the same thing
11-15-2014, 06:18 PM | #32 |
Turbos buy you another ~50rwhp safely since you aren't spinning a blower too. I would have no issues pushing 800rwhp in a turbo car ls3.
Nick
Corvette Z06 -1200ish rwhp |
11-15-2014, 06:26 PM | #33 |
whippled 5th gen
yes it is alot of money im at 718/683 with blower cam plus meth on 13 lbs, should make more power except im at 5000 feet.
11-15-2014, 06:52 PM | #34 |
Scribed....great thread
11-22-2014, 12:36 AM | #35 |
Drives: '14 Camaro 2SS & '96 C1500 Join Date: Oct 2013
I've been looking into putting a blower on mine. I want a loud blower and it seems any reputable brand name make quiet ones for the LS3! Does anyone know of a loud blower from a reputable brand? Is it safe to run 7-9 psi (200-250hp) on stock LS3 with CAI, Lt headers, cat delete w/ npp exhaust?
11-22-2014, 12:46 AM | #36 |
Sold car...
Drives: 2010 Rally Yellow 2SS/RS #37115 Join Date: Oct 2009
Don't do it...it's an addiction!
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust. |
11-22-2014, 01:12 AM | #37 |
There is a voice in the back of my head tell me that but before all that I plan on beefing up the car, adding the power then doing a dyno tune so it will be tuned properly and act as a cap to stop the mod list also with a stock bottom end I won't want to add any more power either.
11-22-2014, 07:49 AM | #38 | |
It can be run at 7-10 PSI safely on pump gas. Ted.
www.jannettyracing.com
11-22-2014, 08:04 AM | #39 |
I think my Ysi is pretty quiet. It makes a little noise, especially when cold, but isn't a super loud blower like a lot of people want.
Nick
11-22-2014, 08:14 AM | #40 | |
11-22-2014, 08:18 AM | #41 |
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM Join Date: Oct 2010
Personally, Id spend the extra $1800 bucks and add the cam when I did forced induction. For no other reason than it will be cheaper in the long run when you have half of the front of the engine area apart in labor and not pay for tuning it again after the cam is install. You figure that saves you about $800 bucks in install labor and tuning, so the cam ends up costing you about $1000.
11-22-2014, 08:52 AM | #42 |
If you are talking about a blower, sure. Turbos don't touch anything up front so can save that for later.
Prochargers can be really quiet, or a little loud if you get a straight cut one.
Nick
