03-17-2013, 11:14 PM | #15 |
Drives: pleather and Chiclets Join Date: Mar 2012
you need these solid mounts...no more cheap rubber bushing
http://www.pfadtracing.com/catalog/p...roducts_id/188
03-17-2013, 11:23 PM | #16 |
03-18-2013, 12:51 AM | #17 |
Drives: '13 Dusk Edition 2SS/RS M6 Join Date: Nov 2012
If the system detects even a tiny bit of slip, usually it'll clamp down that one brake momentarily and the yaw produced gives you the "loose butt" feeling.
I'll bet anything it's just a little slip
03-18-2013, 04:13 AM | #18 |
69 427 435 HP 4:11 rear end and a lotta shit since then, noob my ass
Audente Fortuna Iuvat
03-18-2013, 04:17 AM | #19 |
Again to get back to topic it is not between pavement and tires it's between suspension and car trust me I know the diference.
Thank you all for your help
03-18-2013, 04:22 AM | #20 | |
03-18-2013, 11:32 AM | #21 | |
03-18-2013, 11:48 AM | #22 | |
makes rear end more solid and predictable. no increase in harshness or noise in the ones i linked. helps keep your suspension geometry where it is supposed to be and makes car better with zero sacrifice.
03-18-2013, 02:53 PM | #23 | |
Drives: GM Vehicles Join Date: Jun 2010
Let us know what the dealership was able to find out. We are here if you have any questions. Brandon Chevrolet Customer Service
03-18-2013, 03:47 PM | #24 | |
Drives: 2016 SS Join Date: Jun 2011
03-18-2013, 03:50 PM | #25 |
Jedi Master
Drives: Boeing 757/767+2010 IBM 2SS Join Date: Aug 2008
You're in Boston....if you are driving when it's under 45 Degrees on the stock Pirelli P-Zero tires (summer, ultra high performance design and compound) the rear end isn't going to be nearly as planted to the road as it would with a nice all season tire.
03-18-2013, 04:04 PM | #26 |
Drives: 2017 HBM A10 ZL1 Join Date: Feb 2011
I have the Pfadt trailing arms, toe arms, drop springs, sway bars and end links in my car. I opted for a poly subframe bushing instead of the solid ones. Together they make the car feel very solid. Any movement in the rear of the car under heavy throttle is just driver related now.
My build thread http://www.camaro5.com/forums/showthread.php?t=224342
Go is good. Stop is better. |
03-18-2013, 04:09 PM | #27 |
I would think the more hooked up the tire is the more I can feel it. I have played on damp pavement with traction control off and the tires just spin car fishtails around but I don.t feel the squirm in that situation. When its hooked up I feel the bushings flexing I know that now.
03-18-2013, 04:12 PM | #28 | |
