05-25-2014, 08:27 PM | #29 | |
Snake Eater
Drives: 2012 AGM ZL1 Join Date: Oct 2011
Build Thread: http://www.camaro5.com/forums/showth...95#post8351295
Make sure you don’t forget to subscribe to my channel! More content on the way. Like, share with your friends https://www.youtube.com/channel/UC9Z...sP2wjsLLFeP1zQ Follow me on instagram: http://www.instagram.com/snkeatr/ |
05-25-2014, 09:15 PM | #30 | |
Drives: '21 ZLE A10 Join Date: May 2012
05-25-2014, 09:16 PM | #31 |
Snake Eater
Self install and then take it to get tuned ok?
05-25-2014, 09:24 PM | #32 |
Drives: 2018 camaro zl1 Join Date: Apr 2012
Well I tried to fix it with spark plug anti fouler and eliminating the extensions but the sensor wires are just to short. I am going to try one anti fouler and the extension. I ohmed the extensions ,There is like .32ohms on each of the four wires. My question to those of you in the know, can they tune out the upstream sensors?
05-25-2014, 10:21 PM | #33 | |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
Bryan 2018 ZL1 M6
05-25-2014, 11:30 PM | #34 |
Snake Eater
So when you put headers on. It's going to throw a code and still be able to drive normal with just the CEL light
05-26-2014, 11:24 AM | #35 | |
It will set P015B and P015D
Bryan 2018 ZL1 M6
05-26-2014, 11:44 AM | #36 |
forget the non fouler trick except for purely a diagnosis. Double check the connections on the back of the cylinder heads to the extension harnesses as these areas are tricky access areas and you may not have it clicked in all of the way. The second 02 sensors downstream can be turned off by any tuner to eliminate them.
05-26-2014, 11:57 AM | #37 |
Drives: 2010 zr1 Camaro 2011 vert Join Date: Apr 2013
ARH! The only 100% Amercian made header...And they support this site and Camaro 5 fest....GM FORD and Chrysler use them on there factory hotrods for a reason..
