10-08-2011, 09:45 AM | #29 |
Adding ice to the mix you are running will not cause any long term problems. We do not suggest running strictly ice/water especially for street use
10-08-2011, 08:17 PM | #30 |
Drives: 08' F250 Diesel & 10' Camaro 2SS Join Date: Nov 2010
So all the pictures of S/Cs corroded and stories from water/melted ice are not true?
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 10psi 10.82@130mph TVS2300 ,Hendrix Street Slayer Twin Carbon Clutch, Dana 60 3.73, DSS 1400HP Axles,JRe cam & LaMotta Performance tuned,LPE Fuel, AI Super Chiller,MT ET Streets |
10-19-2011, 12:52 PM | #31 |
If you want to avoid any problems 100% you can make your own ice from distilled water. There are always going to be horror stories.
TANKS ARE IN STOCK AND SHIPPING!!! |
10-24-2011, 07:31 AM | #32 |
We had the car at the track last night and with 69* ambient air our IAT's never got over 118F......and they started at 109F, which means this is less than a 10* rise in IAT's.
When we had this car on the track before with more humidity and about 78* ambient we were starting around 120 and ending up at 140. The tank takes a ton of ice....it is great. We will have a package with the tank and HX up on the site as well as a non fan version of the HX |
10-24-2011, 07:58 AM | #33 |
Drives: 2010 Camaro 2SS/RS White S/C Join Date: Aug 2010
Do you have it for the TVS2300???? Interested.
Thanks
"It does not matter if you win or loose, what matters is if I win" Carl Fogarty |
12-14-2011, 09:01 AM | #34 |
Intercooler Tank Results
Finally some results!!!
As many of you know calibrators have to pull timing once your IAT's reach a certain level. By adding the tank alone and packing it with ice we were able to reduce the IATs well over 10* (the consistent drop was 10) and reduce the rise that we normally see to 2* when it is normally well over 12*. This allowed us to run full timing on the street and the each pass down the track, which resulted in 1.5/10 quicker ET at the drag strip. These are in stock, in the shelf and ready to go and are now for sale at an ALL NEW LOWER PRICE |
12-15-2011, 01:13 AM | #35 |
Car Lover By Nature
Drives: 2016 Hyper Blue Metallic SS Join Date: Dec 2009
okay, say Maggie people like me don't take our cars to the track but we still want this tank for everyday use. will running it with the normal fluid give us any benefit due to the increase capacity or no?
like I said, I don't take my car to the track. but I'd think about this if it's going to help my IATs in the long run. I'm in the Orlando area and as you guys know, the FL summertime weather is brutal.
12-15-2011, 01:34 PM | #36 | |
These are intended to run on the street, strip or both. You will notice a big difference. I do suggest running some Royal Purple Water wetter with it |
12-15-2011, 08:03 PM | #37 |
Drives: 2SS 1LE Join Date: Oct 2011
Nothing to do with this thread, but due to the nature of the IC on my wrx, a fun trick was to take a bunch of ice cubes and lay them on top of the intercooler, it would provide an extra "kick" for a little while. I always thought about making a mold where I could pull it out and have it "fit' into the intercooler, haha.
12-16-2011, 07:33 AM | #38 |
Can this tank be used or converted to a methanol tank?
12-17-2011, 07:32 AM | #39 |
Car Lover By Nature
I wouldn't see why not. only problem u might have is not being able to see the fluid level clearly like how most guys do with the plastic containers. otherwise you'd have to take the cap off to check your level.
12-17-2011, 02:09 PM | #40 |
Sold car...
Drives: 2010 Rally Yellow 2SS/RS #37115 Join Date: Oct 2009
Looks great, just ordered. Hope it can help my iat's during the summer..I have a question regarding using this in a KB setup. The KB tank has 2-3way brass fittings at their coolant tank,smaller line from front of sc and larger going to IC or pump. What fittings are used in your tank? Also the spot where your tank is placed is where the washer tank is relocated to.
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust. Last edited by Rcfiddy1; 12-17-2011 at 08:10 PM. |
12-18-2011, 06:04 AM | #41 |
Drives: 2010 2SS/RS , 2011 C6 Base Corvette Join Date: Feb 2010
Got the Tank
Got the Tank it is sweet, waiting on the cooler with fans
SUICIDE BY RACECAR |
12-19-2011, 11:17 AM | #42 |
Sold car...
What fitting do you have on this tank? Pics?
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust. |
Similar Threads | ||||
Supercharger Intercooler Tanks Available - REDUCE IAT's!!!!!! | Meister@Torq | Forced Induction | 23 | 03-21-2012 07:00 PM |
******* PROCHARGER HO Intercooler System Kit and Tuner Kit Special ******* | DREV LSX | Forced Induction | 27 | 10-07-2011 07:19 AM |
Unbeatble Prices on ACT / Fidanza / Hurst / Mishimoto / MTI / SLP / Spec / More | maperformance | Transmission / Driveline | 18 | 10-26-2010 02:16 PM |
[VIDEO] More drag race development at Rocky Mountain Raceway | PfadtRacing | Camaro Photos | Spyshots | Video | Media Gallery | 5 | 08-25-2010 07:39 PM |
Challenger Fest ! Only 20 spots for Camaros to Drag race | nhra stocker | Dragstrip and Launch Techniques Discussion | 61 | 08-23-2010 06:30 PM |
