Old 12-02-2014, 11:13 AM   #673
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Drives: 2011 2LT/RS Camaro IOM
I went and bought a Styrofoam board and cut pieces and used that to wedge the battery in place and hold it there, haven't had and issues with it moving. This is the best pic I have sorry.
kjkjr27 is offline   Reply With Quote
Old 12-02-2014, 02:55 PM   #674
Black Knight
Black Knight's Avatar
Drives: Supercharged LLT
Thanks that what I wanted to see
CLICK IMG FOR BUIlD THREAD
Black Knight is offline   Reply With Quote
Old 05-14-2015, 04:53 PM   #675
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Been slacking a bit so should prob update my build thread with the latest mods I installed. Over the winter one of the mods I bought was a DSS Al 1-piece driveshaft. The install wasn't horrible just a little time consuming. Only trouble I ran into was installing the u-joint to the transmission. But once that was done everything else was a breeze. There is an overall noticeable difference in how the car performs, especially after switching to the next gear. Much smoother transition. Now was it worth upgrading on my car? Prob not but with the goal I am trying to reach every little bit helps. The only downside to swapping shafts is that it added 1.8lbs back onto the car but that's not that big of a deal. Here are a few pics.
Old 05-14-2015, 04:58 PM   #676
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
The next mod I did was I swapped out my Stage 3 Ported LLT intake manifold and spacer for a ported LFX intake manifold. This mod was a little more complicated with the additional parts that are needed to go along with the actual intake manifold. Once swapped though the LFX intake weighs a total 11lbs lighter than the Al LLT one. That wasn't the only reason I swapped. The LFX one flows much better than the LLT one as well as doesn't heat soak as easily (or at all for that matter). The look on the intake is starting to slowly grow on me although.
Old 05-14-2015, 07:03 PM   #677
HP Turbine
Boosted
HP Turbine's Avatar
Drives: 2012 1LT RS... with snails
I am kind of surprised that it added weight, but it sure does look good.
IPS Twin Turbos, Corsa Exhaust, Ported Throttle Body. 461 rwhp 443 rwtq!! *Cameron Hass.ani*
HP Turbine is offline   Reply With Quote
Old 05-14-2015, 08:45 PM   #678
RubyCamaro
Jan
RubyCamaro's Avatar
Done any drag racing yet?
Old 05-15-2015, 03:53 PM   #679
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Sure does! Upgraded driveline is almost complete haha 1 last mod to do
No I haven't yet unfortunately. Been so busy with work that I haven't had a time to get to the bottom of those injector issues.
Old 05-15-2015, 04:11 PM   #680
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Probably answered somewhere else, but what else does it need?
Lil' Nasty is offline   Reply With Quote
Old 05-15-2015, 05:41 PM   #681
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Under drive pulley
Old 05-15-2015, 10:04 PM   #682
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Originally Posted by kjkjr27 View Post
Under drive pulley
That's needed for the LFX manifold?... I know magnum is running the manifold but obviously we cant run the UD pulley with the SC.
Old 05-16-2015, 02:13 AM   #683
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
O no, thought you meant to finish upgrading my driveline,
Old 05-24-2015, 12:59 PM   #684
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Little update: for Christmas I got a set of the vitesse paddle shifters and today I finally got around to installing them haha. They look sexy in black, however might remove them and paint the "+" "-" IOM, prob should have thought of that before installing, o well
Old 05-24-2015, 05:11 PM   #685
Aequitas & Veritas
Aequitas & Veritas's Avatar
Drives: 2010 Camaro 2LT RS, 2009 GTR
I vote IOM for the paddles! Before tends to be a bit easier but it happens. I love mine in IOM so I think you will too.
Aequitas & Veritas is offline   Reply With Quote
Old 05-24-2015, 07:24 PM   #686
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Well I think I'm gonna leave the paddles black, just paint the plus and minus symbols. I do plan on getting the speedo and steering wheel bezels painted IOM so don't want too much IOM in that area
12secbuild
[COTW 3/21/11]: "MAC" GB EB Member Car Journals 172 03-27-2014 06:50 PM
SlowSS's Build Thread SlowSS Member Car Journals 47 03-01-2014 11:20 AM
HOW MUCH $$$ HAS CAMARO5 COST YOU? GB EB 5th Gen Camaro SS LS LT General Discussions 117 02-18-2013 11:10 AM
[COTW 11/29/10]: My 2011 IOM 2SS/RS's journey lock Member Car Journals 66 06-08-2012 09:34 PM
Blake's unique IOM LED Crazy Member Car Journals 9 06-02-2011 12:49 AM
