03-22-2019, 04:02 PM | #57 |
Drives: 2017 SS 1LE Join Date: Mar 2016
I'm at -2.5 front/-1.5 rear so hopefully that's enough, I will just leave them alone for Tuesday and see how they look when I get back home. Thanks for the input!
IG: @NC_M1SS1LE
03-22-2019, 07:57 PM | #58 |
SABIO
Drives: 2016 CAMARO 1SS Join Date: Jul 2015
APEX has group buys on the BMW forums. As we know they are BMW wheels. Not enough people were interested to get a good discount so I didn't bother with that group buy. Keep checking them out, the group buys pop up often.
03-30-2019, 07:07 AM | #59 |
I'm wanted the 19" setup so I can try the G3R tire at least once. Then work toward getting into the new NASA 200 UTOG TT
03-30-2019, 09:42 AM | #60 |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
03-30-2019, 10:14 PM | #61 | |
Drives: 1LEs Join Date: May 2009
The “Hoosierstones” are a 200TW cheater tire. Just don’t heat cycle them out by driving on them to / from track per the guys that run them. For TT, they’d probably work well by coming up to temp quickly and getting your hero lap done early. |
03-31-2019, 07:16 AM | #62 |
Drives: 2017 Camaro 1SS Join Date: Aug 2016
Assuming that Apex actually does come out with the Camaro fitment (hub centric and correct offsets), those should be a nice choice for 19s. Supposedly coming out in May this year?
04-01-2019, 05:01 PM | #63 | |
Drives: 2018 2SS 1LE in Nightfall Gray Join Date: Jul 2018
JD |
04-01-2019, 10:12 PM | #64 |
Drives: 2018 SS 1LE Hyperblue Join Date: Jul 2017
04-02-2019, 07:02 PM | #65 |
Drives: 2017 Camaro 1LE Join Date: Jul 2018
04-02-2019, 08:57 PM | #66 |
Drives: 2017 1le current /2015 2ss 1le sold Join Date: Jan 2016
Is a 20mm spacer upfront excessive? To make the 305 square setup work
2017 1LE Hyper Blue
04-02-2019, 09:45 PM | #67 |
A few of us are running the 19x10.5"s w/ 305s square with a 5mm spacer up front. But the caveat to that is if you are going to run more than about -2 degrees camber up front you will also need to grind the strut a bit (sounds scary, but no big deal). OR get a 10 or 12mm spacer and you should be GTG, the 20mm is definitely overkill. Also anything over 5mm space you will need extended studs.
IG: @NC_M1SS1LE
04-03-2019, 06:44 AM | #68 | |
2017 1LE Hyper Blue
04-03-2019, 08:02 AM | #69 | |
Drives: ISO ss 1le Join Date: May 2018
I'm fairly close with Ryan the sales manager of Apex, and the way he explained not having "better" square offsets is that the ET22 for the rear is just too low and pokes a good amount, and in their survey people were not voting for that. If you wanted to run an et22 square setup just get the wheels with BMW hub bores and run a ring adapter, no big deal. I've done it on my 19" and now 18" setup and have been on sebring 10+ times, barber for 3-4 days and have not had an issue with them, or the spacers (albeit i only run a 5mm spacer). Any questions specifically, let me know! |
04-03-2019, 12:09 PM | #70 |
^^^What he said^^^
I didn't realize that the offset was 35 on the "Camaro" 19x10.5s. I have to agree 100% that you would be better off with the "BMW" ones that are 22 offset. The rear poke is negligible, and personally I think it gives the car an even better looking stance with the slight poke in the rear. Tough I agree with Alex about running spacer not being as "scary/sketchy" as a lot of people make it out to be, I'd rather run the hub rings on the BMW spec wheels and a 5mm spacer than no hub ring and a 20mm space on the Camaro spec wheels. I really don't understand why people would have voted for 35 offset on the square setup. Also as Provoste said somewhere in here the "poke" in the rear widens the track widths and makes it more stable and the rear feels absolutely planted!
IG: @NC_M1SS1LE
