Old 02-16-2015, 03:15 PM   #57
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Those wheels and tires will not fit Jesse.
First off like in my first post, I listed all the wheels that fit our cars.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 02-16-2015, 06:07 PM   #58
jesse454545
Drives: 2011 CAMARO 2SS/RS
Thanks I just started looking into drag tires and not sure about the fitment. I read the whole thread but wasn't to sure I was understanding everything right. I have to do some slick studying lol
jesse454545 is offline   Reply With Quote
Old 02-16-2015, 09:08 PM   #59
Pro Stock John
Writer
That slick setup might be for a Chevelle or something.
On our cars, they might stick out the fenders. But the wheels themselves will be right up against the brake.
PROJECT HEAVY CHEVY
Old 02-19-2015, 10:58 AM   #60
62nalide
62nalide's Avatar
Drives: 2013 SS
15" ADM Kit
Weld RTS 15x10 with a M/T ET Pro 275/60/15
62nalide is offline   Reply With Quote
Old 02-19-2015, 11:12 AM   #61
Pro Stock John
Writer
Looks great Martin.
PROJECT HEAVY CHEVY
Old 02-19-2015, 11:47 AM   #62
62nalide
62nalide's Avatar
Drives: 2013 SS
I'll take pics soon, once my front tires are in so I'll be running 15x10 out back and 17x5 up front.
Old 02-19-2015, 12:27 PM   #63
Merc
In The Circle
Merc's Avatar
Picking up a set of road race tires and wheels today for Pumpkinn. Toyo 888's on TSW's
Name:  Screen Shot 2015-02-09 at 1.41.15 PM.png
Old 02-19-2015, 01:11 PM   #64
RGRCamaro
RGRCamaro's Avatar
Drives: 2011 Camaro 2SS
So is Nitto the only one with a 315/35/20?
2011 Camaro 2SS/RS LS3 M6 - 672rwhp/581rwtq - 91 octane tune
RGRCamaro is offline   Reply With Quote
Old 02-27-2015, 11:44 PM   #65
BrainleSS
Working on my 2nd one!
BrainleSS's Avatar
Drives: Camaro
62nalide 1/27/15
I'll post pics later today if folks want pics of different setups
15" ADM Kit
Wow don't kill us all at once, with all those diff setups you mentioned!
Especially the most common setup
[SIGPIC][/SIGPIC]
BrainleSS is offline   Reply With Quote
Old 03-01-2015, 11:02 AM   #66
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
I currently have a set of 20X10's in the front and 20X11's in the rear, I am going to go with DR's on the 20 inch rear wheels and get a set of 17's for the track.
Can I run 17X11 or 17X12 on the rear if I change my LCA's? Also, is it really worth going from a 10 inch to 11 or 12 inch wheel if I can do it?
Is it ok to run radials up front and DR's on the back, or should I not mix them, should I just do DR"s all the way around?
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 03-01-2015, 08:12 PM   #67
Pro Stock John
Writer
1Killer, just DRs in the back since we are RWD.
Regular radials and DRs can be mixed, we do it all the time.
Martin might have run 17x12s once, but I think they are generally on the side side. 17x10 or 17x11 would fit better.
PROJECT HEAVY CHEVY
Old 03-01-2015, 08:36 PM   #68
1KillerSS
1KillerSS's Avatar
Thanks, on welds website they don't show a 11 inch wide for a 5th gen. Thats why I was asking about size of wheel. All they will show is an 17X10.
Build thread
Old 03-03-2015, 10:45 AM   #69
62nalide
62nalide's Avatar
Drives: 2013 SS
15'' ADM Conversion done!
Tires used 275/60/15 M/T Pros on Welds RTS 15x10 (5x4.75s)
Fronts= Phoenix 4.5/27/17 on welds RTS 17x5 (5x120)
Old 03-03-2015, 11:23 PM   #70
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
That is just straight up Bad ASS!!!
