Old 09-21-2010, 11:19 AM   #85
Blackhawk6
Blackhawk6's Avatar
Drives: Born:18 Sept 2009 #47903
Took my 2SS into the dealer and they replaces my front brakes under warranty.
Document ID: 2423856
#10-05-23-002: Front Brake Squeak Noise on Brake
Apply (Replace Front Brake Pads) - (Mar 25, 2010)
Subject: Front Brake Squeak Noise on Brake Apply (Replace Front
Brake Pads)
Models: 2010 Chevrolet Camaro SS
Built Prior to VIN Breakpoint A9172924
2010 Camaro 2SS________________________________________Litho#140
Blackhawk6 is offline   Reply With Quote
Old 09-21-2010, 11:21 AM   #86
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Brake Pads)
This replaces the wheel weights on the calipers with rollers on the pads?
Old 09-21-2010, 01:08 PM   #87
Primus
2G1FF1EV0A9113319
Primus's Avatar
Drives: 2010 1LT/RS 6MT
Very different noise than the squeal and an indicator that something is not right.
Cricket = clicking and possibly a pad or retaining clip not seated correctly?
Bed Spring = Squeaking and Screaming That can't be a brake noise
Brakes are NOT a joking matter so please excuse the humor. Any mechincal brake noise requires an immediate inspection. Please get your wheel off drill as deep as removing the rear rotor to inspect the parking brake.
Once last thought, do you have after market wheels and TPM sensors. The valve stem style TMP senors have been known to 'click' against the parking brake cable.
No, I have the RS wheels. I'll take the wheel off and at a minimum remove the caliper to see if something's going on with the pads or retaining clips ASAP.
Thanks.
2010 Camaro 1LT/RS M6 Black
1100: 10/13/2008
2000: 4/02/2009
3000: 4/08/2009
3300: 5/14/2009
3400: 5/21/2009
3800: 5/28/2009 VIN: 2G1FF1EV0A9113319
4000: 5/28/2009
4150: 5/28/2009
4B00: 5/28/2009
Delivered: 6/10/2009
Primus is offline   Reply With Quote
Old 09-21-2010, 01:22 PM   #88
JusticePete
Thanks.
and you are welcome.
Old 09-26-2010, 11:00 AM   #89
Primus
2G1FF1EV0A9113319
Primus's Avatar
Turns out my rear drivers side nuts were a bit lose on my wheels. I guess that should have been the first thing I checked but I was so sure it was the brakes I didn't even bother checking those nuts initially. I meant to go back and check them again a few days after the installation but I never got around to it.
I feel lucky something bad didn't happen....
1100: 10/13/2008
2000: 4/02/2009
3000: 4/08/2009
3300: 5/14/2009
3400: 5/21/2009
4000: 5/28/2009
4150: 5/28/2009
4B00: 5/28/2009
Old 09-26-2010, 11:39 AM   #90
Revo1
Don't Like it? Suggit.
Drives: 2010 2SS/RS
Any fixes? I'm dyin here...
Old 09-26-2010, 12:32 PM   #91
Markel
Drives: 2010 L99 2SS/RS
FWIW, my 2010 SS is 200,000+ VIN range with 3,000+ miles. No squeal issues.
Markel is offline   Reply With Quote
Old 09-26-2010, 02:11 PM   #92
SleepWarz
Banned
Drives: 1991 New Yorker, 69 Tbird, ABM2SSRS
Me too =(
SleepWarz is offline   Reply With Quote
Old 09-26-2010, 02:55 PM   #93
musclecargirl
musclecargirl's Avatar
Drives: 2010 2SS CGM w/IO Interior
I had the same squeak with the brakes. I put on Hawk performance ceramic pads and no more squeak.
musclecargirl is offline   Reply With Quote
Old 09-26-2010, 06:58 PM   #94
ArkySS
Camaroless for now...
ArkySS's Avatar
Drives: 2014 Blue Topaz Silverado
Okay maybe I missed reading it but do your front pads have the roller skates Revs?
It was fun while it lasted.....
ArkySS is offline   Reply With Quote
Old 11-20-2010, 02:23 PM   #95
cactuseater
Drives: .
I have noticed that taking your Camaro through a car wash will eventually wash away the lubricant on the back of your pads. A squeak is a frequency, and it's more than likely caused by these little buggers lossing the grease. I noticed it on my Corvette when I power washed the wheels on the car, squeaked like crazy. Took them off and re-lubed the brake parts -- there was nothing there they were dry -- and squeak is gone. Pretty common. I hand wash my SS and refuse to use car washes because of the high pressure water.
cactuseater is offline   Reply With Quote
Old 11-20-2010, 03:05 PM   #96
Revo1
Drives: 2010 2SS/RS
Yup... The squeal weights right? Not doin much good :/
Old 11-22-2010, 11:01 AM   #97
Chris_B
Chris_B's Avatar
Drives: Several
High-pressure washers and brakes don't always get along very well. I would advise against using them for at least this reason.
Chris Bernal
Brake Maven
Chris_B is offline   Reply With Quote
Old 11-22-2010, 11:05 AM   #98
Bob
coffeemanbob
Bob's Avatar
Drives: 4Malibus,Z28.....back when!
Dealer replaced my pads after 11000 miles! Sqealing gone.
coffeemanbob
Bob is offline   Reply With Quote
Drum brakes hard to beat KILLER74Z28 General Automotive + Other Cars Discussion 17 02-16-2012 12:40 PM
Brembo Brakes ChevyBoiSS Wheels and Tires Talk Sponsored by The Tire Rack 15 02-03-2009 07:23 PM
What's written on the brembo brakes FUTURE TOP DOG OWNER 5th Gen Camaro SS LS LT General Discussions 19 09-19-2008 08:11 PM
Brembo brakes question topgun1 Wheels and Tires Talk Sponsored by The Tire Rack 20 09-04-2008 10:34 AM
EWB Electronic Wedge Brakes KILLER74Z28 General Automotive + Other Cars Discussion 10 11-13-2006 12:12 AM
