Old 08-12-2017, 02:47 PM   #99
mrimpala02
Drives: Black 2SS RS w/White Stripes
With those 3.91's I would imagine you were at the top of 4th at the quarter right?
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods |
Installed by Me & Tuned by Pat G
mrimpala02 is offline   Reply With Quote
Old 08-12-2017, 06:05 PM   #100
hillshooter
Drives: 2015 Camaro SS commemorative
[QUOTE=mrimpala02;9863301]With those 3.91's I would imagine you were at the top of 4th at the quarter ]
I figure I am good to low 140's . So probably about there , you are correct sir. I only hope I can keep that read end alive , I am also stock axles ! Yikes
2015 Camaro SS, LS3 Stroker, PRC heads,CUSTOM CAM. AGP 68/68 with custom Hot and Cold side. Fore triple pumps, Holley terminator X. BMR drag suspension with carlyle brake kit. 15" ET drags and 17" skinnies. ZL1 3.73 gears , aluminum driveshaft. TH400 with circle D converter.
hillshooter is offline   Reply With Quote
Old 08-12-2017, 10:00 PM   #101
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
Good time man, plus I know there is more to come soon you should be knocking at the 9's but like you said your limitation is that rear, it limits you on how hard you can launch her
Cai intake and a few other mods😎
Moreair1 is offline   Reply With Quote
Old 08-12-2017, 10:30 PM   #102
mrimpala02
[QUOTE=hillshooter;9863461]
I wonder would you be trapping higher with a 3.45's or 3.27's? But yeah the rear and axles are definately a concern for hard launches. Looking forward to times after cooler weather!
Old 08-13-2017, 06:55 AM   #103
Ls1408cp
Drives: 14 1le turbo
Originally Posted by jasycz28 View Post
What is this new AGP intake plenum you speak of?
I'm not sure why he's not advertising it but here it is.
2014 1LE 2SS/RS
Huron Speed turbo kit
Ls1408cp is offline   Reply With Quote
Old 08-13-2017, 08:52 AM   #104
Scotty D
Drives: 2014 1le 1SS CRMT
You sure that's not the Huron one?!?!?!? ��
Scotty D is offline   Reply With Quote
Old 08-13-2017, 10:39 AM   #105
Ls1408cp
Nope I had them do it last week. That's not my pic and this bottom one isnt
2014 1LE 2SS/RS
Old 08-13-2017, 10:48 AM   #106
blake-b
blake-b's Avatar
Drives: 2009 ZR1
The bottom pic is of mine. I also have it on my car. Here is another. The undercar is JessRayo's car.
Old 08-13-2017, 11:24 AM   #107
Scotty D
Hmmm. Ok sorry to doubt you bro
So they're welding onto the turbos now ?!?!
Old 08-13-2017, 12:31 PM   #108
Moreair1
Moreair1's Avatar
I believe it's because the standard plenum is plenty for most of us, this new plenum is really for extreme builds like blake-b's where your making 1k plus
Old 08-13-2017, 12:57 PM   #109
blake-b
blake-b's Avatar
Drives: 2009 ZR1
The turbo outlets have to be redirected for the new piping.
Old 08-14-2017, 05:34 PM   #110
white1LE
white1LE's Avatar
Drives: 2013 Camaro ZL1
Ran mine yesterday. 10.7@146 with a 2.1 60'. Boost was 2 psi short of my max 21. Stock stall and 6l90 which have yet to be touched at 27,000 miles. AGP Turbo kit was installed at 9,000 miles 1 year ago june. Drives like a stock car, love it! Running the EFR-7670 57mm turbos. Not one issue with this kit ever. Excellent work AGP!!!
13 ZL1 A6
LSX 427 with AGP Twin Turbos, E85 and Flex Fuel. Built and tuned by ADM Performance
1000rwhp
white1LE is offline   Reply With Quote
Old 08-14-2017, 06:46 PM   #111
Unavowed
Unavowed's Avatar
Drives: Twin turbo G8 GXP
Geez, were you on street tires? I know the stock stall is killing it, but you should still be able to pull 1.8x 60' with a drag radial on the stock stall.
Unavowed is offline   Reply With Quote
Old 08-14-2017, 09:15 PM   #112
Redlineviper
Redlineviper's Avatar
Drives: 2013 ZL1
With a stock 376 with 9.1 compression my car cuts 1.92-1.94 like a bracket car in the 60' (stock stall). There just isn't any power off the line to cut a better et, it's not a traction issue.
2013 A6 ZL1
Redlineviper is offline   Reply With Quote
