08-27-2020, 08:35 PM | #113 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
FLEX SEAL!!!!
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
09-04-2020, 04:35 PM | #114 |
I just ordered a Dart 427 from them today. It’s the 1800hp rated one they just put on sale this month. I wasn’t really planning on buying an engine this soon but I thought it was a pretty good deal. Broke the snout off my SBE LS3 a couple weeks ago, luckily it still had oil pressure though.
09-04-2020, 10:00 PM | #115 | |
2010 transformer
Drives: 2010 ss camaro Join Date: Nov 2014
2010 transformer, vertical doors, 315nt05 rears, pedders supercar coilovers, hotchkis sway bars, links, adjustable, toe bars, bmr poly cradle bushings, 1le control arms, bmr tunnel brace, bmr subframe connectors. Cam 227/239-623-620@114 Mast medium bore heads, sw 1 7/8 headers, cat delete, x pipe, 3" dynomax true duals, fuel rails, fast 102 intake and NW 102 throttle body, catch can, rotofab cai, shifter, raptor custom shift light. Dss drive shaft, 3.91 gears. 492 rwhp
09-05-2020, 12:35 AM | #116 |
Drives: 1970 Pontiac Firebird L8T Join Date: Dec 2016
09-05-2020, 09:26 AM | #117 |
https://www.thompsonmotorsports.net/...plsnext-1800hp
That’s the link to the shortblock. They don’t have the sale advertised on the website but they do on Facebook, it’s around $6700 for the short block. |
09-21-2020, 07:21 AM | #118 | |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
I had to drive cross country to bring a friend home from Alaska, remodeled the beach house kitchen and finally got the radiator replaced. The G4 is in and its definitely making more boost. I started with the 95mm pulley and saw a peak of 18psi at 7300. Today I’ll swap in the 90mm sc pulley which should bump it up to 20. IDC is at 80% though. Gotta keep an eye on that, but other wise the tune is still really close. Only about 2% maf error above 4000rpms. I’m gonna pull 1 degree of timing, do a few street pulls to see if its happy and then hit the dyno. It’s pretty wet if Florida this week, so gotta wait on that. I did 4 60mph hits for data collection and it spun the first 3 times around 90mph. The 4th pull stayed mostly planted. Pulls nice when it hooks. https://youtu.be/65g50lFPpoA
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
09-21-2020, 11:30 AM | #119 |
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
Insane!
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi |
11-24-2020, 06:40 AM | #120 |
15s
The 18inch wheels just wouldn't cut it. It was just unusable. Had to do the 15 inch conversion. I went the BMR route with Carlyle brakes. I can hardly tell that the rears are grey and the fronts are darkstar. Looks good enough for me.
I bought the wheels/tires/brakes from a local guy and just noticed the tires are from 2017. First 60mph pull it spun as usual around 5200rpm. I decided to install a larger pulley, drop tire pressure to 17cold, stiffen up the rear coilovers and move the BMR anti roll bar to the middle hole. After warming the tires a bit, I was able to hook up decent when rolling into the throttle in second gear with some spin up top. It's an improvement. I'll just have to keep working on it until I can turn the boost back up. Looks like its only making 16psi right now, but havent taken it to 7000.
11-24-2020, 09:52 AM | #121 |
Dan
Nice!
Dan
11-25-2020, 02:52 AM | #122 |
I have the same setup on my car. I just haven't driven it yet.
11-30-2020, 04:16 PM | #123 |
Drives: Vette Join Date: Dec 2010
Put the air filter on your unit and you will see 1000.
12-01-2020, 06:01 AM | #124 |
I'm guessing you mean to remove the air filter? I don't think that's necessary, but we will see. I'm already running the AirRaid Track Day air filter. It's basically just a very fine screen. It doesn't filter as well as the K&N, but it flows much better. The larger G4 blower should get me to 1000 without meth or removing the filter housing. We'll see in a couple weeks.
Besides the air filter piping provides the vacuum source for my Crank case ventilation. I would rather not pop the rear or front crank seal just to make a number. If it makes 999, it is what it is.
12-01-2020, 05:15 PM | #125 |
What was your old wheel/tire setup?
12-01-2020, 05:37 PM | #126 |
Same fronrs. Rears were 18x10.5 racestars with 305/45/18 MT ET R
It hasnt hooked well for me, for quite a while.
