Old 12-02-2016, 06:30 PM   #1
The Wanderer
Drives: Blaze Red 2014 2SS/RS
Noob with a question....
I own a 2014 2ss/rs that as far as I can tell by my build sheet that it is loaded with all options it has the strut brace, stiff suspension, brembos ,performance sticker on the top of the rad. support etc. My question is it does not have the performance exhaust is this because it has an auto transmission or is the only option that was not ordered on the car....I bought the car in June used it only had 2800 miles on it
The Wanderer is offline   Reply With Quote
Old 12-02-2016, 07:13 PM   #2
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
Welcome!
The NPP exhaust was never offered on the L99 because of the AFM.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 12-02-2016, 09:53 PM   #3
LoneCynic
LoneCynic's Avatar
Drives: 2015 BVM 1SS/1LE
You are correct, the NPP is/was a manual transmission LS3 equipped car only option on SS. Otherwise, sounds like you are quite loaded on the options list.
LoneCynic is offline   Reply With Quote
Old 12-02-2016, 10:16 PM   #4
The Wanderer
Thanx to all who replied.....
Old 12-02-2016, 10:57 PM   #5
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
What performance sticker is on the radiator? Is this the first Camaro you've owned?
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 12-02-2016, 11:27 PM   #6
jcaligood
jcaligood's Avatar
Drives: '18 SS 1LE
i think he's talking about "GM Performance Division" emblem on top of the radiator shroud cover.
My 2010 L99 had it, but my 2011 LS3 does not. hmmm..
jcaligood is offline   Reply With Quote
Old 12-02-2016, 11:58 PM   #7
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
does it have a sunroof and Navigation? The 2SS is basicly loaded except for dealer installed options.
JCunningham is offline   Reply With Quote
Old 12-03-2016, 02:14 AM   #8
CamaroFred
CamaroFred's Avatar
NAV was included on all the LT/SS but you need the Onstar subscription for it to download the directions.
Sunroof was an option on all LT/SS but you loose the reverse Mohawk and headroom.
2011 1SS/RS LS3 CGM
Old 12-03-2016, 06:05 AM   #9
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
Wow NPP was never offered on an automatic? That's sad. Own an auto, get stuck with crappy sounding exhaust...
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 12-03-2016, 08:39 AM   #10
The Wanderer
It has the sun roof the car I believe has every option that was available
Old 12-03-2016, 09:01 AM   #11
The Wanderer
http://www.camaro5.com/forums/attach...1&d=1480777035
Old 12-03-2016, 10:29 AM   #12
redcoats1976
wow...even has the deerhorn mechanics coverall rack option.havent seen that before.enjoy the new camaro...
Old 12-03-2016, 12:58 PM   #13
JCunningham
Drives: 2017 2SS M6
im talking about the Mylink navigation thats a option. nav and sunroof were the only 2 options a dealer couldnt install when you bought the car. Nav could be dealer installed but cost way more then ordering the car with it.
if he has mylink navigation then he has every option.
Old 12-03-2016, 01:32 PM   #14
The Wanderer
I have it but I do not subscribe to onstar
