12-12-2011, 12:46 AM | #1 |
Drives: '10 IBM 2SS, '01 Black SS Join Date: Jun 2009
Video - Why Is My Sub Doing This?
So a couple seconds after I turn my car off, the sub hits real hard when the amp shuts down. What is causing this? It wasn't doing it when I was using a Line Out Converter, it just started when I started using the speaker level inputs (because the LOC broke so I got rid of the RCAs). I used the same ground point for my speaker level inputs as the main ground for the amp, would that have anything to do with it?
Here's a picture of my amp inputs on Sonic Electronix's site. |
12-12-2011, 08:19 AM | #2 |
Drives: 2010 Join Date: Mar 2010
The speaker outputs turn off before the amp turn-on line from the radio drops. You need to use a different turn-on line. Some people have used the cigarette lighter wire with good results. There is a product that addresses this specifically, the Axxess Trigger, which you can get from SonicElectronix.com. Or you could just go back to your LOC that you were using before...
12-12-2011, 09:35 AM | #3 | |
I'll check out that Axxess Trigger. |
12-12-2011, 12:10 PM | #4 |
Your line level converters probably provided better common mode rejection than your speaker level inputs. The LLC probably also contained a lower value load resistor that forced the two lines to "track" better after the radio released them.
