02-18-2015, 08:38 AM | #1 |
Drives: 2010 ss rs ls3 red-white rallys Join Date: Oct 2008
Drone free axle back
Running a cam, headers and no cats and think I have burned up one of my oem mufflers...getting a rattle sound from one of them..like I have burned up the baffles inside..that can happen right? So now looking for an axle back...which axle back is drone free...I see where corsa doesn't offer a axle back...any suggestions..
eps cam 226/234 lsa 113+2, bfe 1 7/8 headers, rotofab cai, katech oil pump, 444 rwhp, 411 rwtq, eps tune, Blanchard performance install
02-18-2015, 09:02 AM | #2 |
Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
Solo Axle Backs with J-Pipes. Sounds great and as close to drone free as you can get.
02-18-2015, 09:22 AM | #3 |
Drives: 2017 NGM 2SS Vert Join Date: Mar 2014
+1!!!!!!!
2014 Red Hot 2SS/RS
02-18-2015, 09:30 AM | #4 |
What am I looking at spending getting this combo?
02-18-2015, 09:35 AM | #5 |
Ok I see now...about 500ish.....any sound clips on this with a cam?
02-18-2015, 10:03 AM | #6 |
Drives: 2018 Camaro ZL1 Join Date: Mar 2013
The stock mufflers are pretty much a straight through design. There is a cut away picture around the forums somewhere. It is essentially a pipe with holes poked in it and sound deadening material all around. There are not chambers or baffles really so I am not sure what would be rattling.
02-18-2015, 10:14 AM | #7 |
Drives: 2011 Summit White Camaro SS (LS3) Join Date: Sep 2014
Solo's are what I'm getting as soon as the mountains of snow disappear ($500).
J |
02-18-2015, 11:14 AM | #8 | |
02-18-2015, 11:20 AM | #9 |
my drone free system is jba headers and hfc's..with ls3 pipes my friend gave me to replace the l-99 pipes with resonators, and end with borla s-type axle backs.
02-18-2015, 11:37 AM | #10 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
Or add J pipes from solo or get them made. Then can do whatever axelback you like
02-18-2015, 12:36 PM | #11 |
Drives: 2010 2SS/RS Camaro Join Date: Aug 2014
You could always build your own CENTER EXIT / AXLE BACK system like I did for my2010 2SS/RS L99.Also with no drone! Just not quite finished yet. For more information, PM me, I will be glad to help. Also your neighbor won't have this on their Camaro!
All The Best, Orange 2010 Camaro |
02-18-2015, 01:43 PM | #12 | |
02-18-2015, 02:02 PM | #13 |
Drives: Iron Lung, Jimmy Join Date: Jun 2009
What is rattling is the plate that separates the stock muffler into two chambers. When mine started to rattle I drilled a small hole next to the plate and could stop the rattle by pressing on the plate with a screwdriver. But I could not figure out a way to permanently fix it so I went with the Solo w/j-pipes cat back system.
Solo axle backs with headers and no cats will be ridiculously loud. If you go with Solo... which I would recommend... get the cat back. Super sweet sounding system. No drone. |
02-18-2015, 04:36 PM | #14 | |
Thread Tools | |
