07-11-2009, 07:31 AM | #1 |
L99 Mission for the day.
Today I want all L99 owners reading today to do this.
Go put your car in M. Turn of traction control. Now take foot of brake and stomp the gas. Report back if your rear end broke loose and post picture of burnout. NO POWER BRAKING or BRAKE STANDS. Think about it, a 400HP, 410Trq car should be able to break them loose doing that and leave a mark on the road. My familys 79 TA would do that all day long and it had nowhere near the HP and TRQ todays Camaro has and we had the WS Packgage and the Olds 403 motor. Go look at the specs of that TA. This car should be killing that car in performance. Mine is not. Lets see what yours does. |
07-11-2009, 07:40 AM | #2 |
Drives: 6 camaros Join Date: Feb 2009
but prob. not new designed tires and 275 wide and VERY tall... that makes it hard to spin, not to mention the computer doesn't want it to with the torque management. That may be your only issue... maybe its just hitting that or set way to low and almost going into a limp/fuel/timing mode. I know for a fact it limits those when it hits any torque management limit.
As well as I believe the throttle blade is closed in certain conditions. I set all mine off and made a big difference (even stock)
2010 IOM RS/SS TVS2300, cam, stall, headers
2002 Z28 427 2002 SSLE Convertible 1968 383 Camaro 1968 327 Camaro Convertible 1967 RS 327 1967 Pro-Tour LS3 in progress |
07-11-2009, 07:43 AM | #3 | |
07-11-2009, 07:52 AM | #4 |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
Yeah, its going to be difficult with new 275 series summer tires, tons of torque management, and warm temps.
This winter when its 40 degrees outside it will be easy to spin the tires. 1. Car makes more hp in cold air 2. Summer tires don't hook up very well on cold pavement. Also the tire compound is harder in cold weather. But right now in S. Florida summer conditions if I mash the gas ( M mode - TC off), I get just a tiiny bit (I mean a tiny bit) of wheel spin and the car just takes off. What's needed is a tranny tune (reduce torque management or no torque management), and cooler temps, and you'll be wishing you could hook up. |
07-11-2009, 07:58 AM | #5 |
Drives: 2015 Audi S6 Join Date: Apr 2009
Coming from a drag racing background, I love a car that dead hooks on the street! This thread cracks me up. Get a tune! Reducing torque management will change your hooking problem lol.
2015 Audi S6
07-11-2009, 07:59 AM | #6 |
its in the tranny and ecm tune... need a tuner to do so.. I know.. shouldn't have to, but maybe gm is/was trying to slip this by some of us. (as in low performance)
07-11-2009, 08:33 AM | #7 |
VIN #3026 IOM/IO
Get it Tuned
Scott,
4000 lbs with good weight transfer plus large tires and torque management...it's not a 1979 car - it won't spin. Trust me on this. If you want to see what the L99 can do - get it dyno tuned and make sure they work on the torque management and tranny shifting. I gained over 100 ft-lbs off idle due only to torque management delete. Even with this it won't roast them unless I bring it up on the converter - GM did a good job making it stick. BTW my car is a 12-second car now with the tune, CAI, and axle-back exhaust. Good luck with the car
07-11-2009, 08:46 AM | #8 |
Blessed
Drives: 2013 Sonic RS MT Join Date: Dec 2007
a couple of people here have said get a tune.
If you mean have GM reflash or retune then fine. But the objective is to fix the problem without voiding any part of the warranty. So lets keep the criticism consructive please.
Click image to see build thread. PQ - "the love of cars. It's a boys first step toward manhood and a mans last hold on boyhood." Fbodfather - "We do not want to use the Z28 moniker on a car that does not deserve this hallowed name." The_Blur - "Let's not confuse competitors with equals." |
07-11-2009, 08:48 AM | #9 |
Drives: 2010 VR 2SS/RS A6 Join Date: Oct 2008
Ok scott. I did it and my tires break loose. It is 75 degrees and about the same in humidity. I dont smoke them but I get a nice long chirp. Everything is stock on my car.
Intelligence plus character that is the goal of true education.
BrianC. :flag2: |
07-11-2009, 09:09 AM | #10 |
This is a performance and powertrain forum. Aftermarket calibration is completely valid and relevant and very much constructive. This happens with EVERY car, fellas. It takes about 3-6 months before the "oh my god my warranty!" factor starts to crawl off and people realize that modifying your car isn't armageddon. See Magnuson-Moss warranty act: http://autopedia.com/html/HotLinks_LemonMM2.html
Yes the car is probably a little slow from the factory. I'm sure torque management has 80% to do with it, break-in mileage has 10% to do with it, and over-assumption probably takes up the last 10%. This car in an auto cant really be expected to roast the tires with as much weight as it's putting out as well as the conservative GM calibration. Sounds like a certain 6.1L competitor I know of, eh? I'm in no way saying that an aftermarket tune should be the immediate fix in this situation. Give it some mileage, check back with the dealer (you know they'll have a TSB or two with a nice PCM update slipped in there under the radar). If at that time, you're still not happy with the performance, go throw it on the rollers with a nice CAI and watch the difference with a custom tune! And hopefully by then when someone mods their car, everyone won't be all in slow motion like "NOOOOOOOOOOO! DOOONTTT DOOOO ITTTT!!!!!" That's not attacking anyone in general. I noticed it in MANY threads on this forum. It's not as big of a deal as we all would assume. I've been delivered multiple cars right from the dealership in their respective states to us for supercharger installs, and shipped to their owner freshly charged-n-tuned. See Tillman Speed 2009 Mustang GT Whipple Supercharger / Kooks Longtube Header / Hurst Shifter / Gauges / Clutch&Flywheel project we're working on right now. Car has 238 miles. Chris Rose Tillman Speed Inc. |
07-11-2009, 09:40 AM | #11 |
Petro-sexual
I don't think anyone's saying don't do it, however, I can feel the frustration in that it seems like GM may have watered the L99-cars down a little. Given, the vehicle's only been out for a few months, and there could be some TSBs and reflashes GM might come out with, but I'm another for thinking this is frustrating. I, personally, don't think it should have to come down to a whole lotta' TM to protect the drivetrain. We've been told the rear end on these is good for more than 600+ horsepower and this is the same tranny as is in the 'Vette, so it should be pretty stout to start with. No one is saying the aftermarket doesn't deserve it's place here; it's not about that at all. If a car has 400 horse, it should punish the tires unless it's AWD or 5000 lbs.; neither of these is Camaro.
That's how we're going to keep this constructive...
'20 ZL1 Black "Fury" A10, PDR, Exposed CF Extractor Magnuson Magnum DI TVS2650R // RFBG // Soler 103 // TooHighPSI Port Injection // THPSI Billet Lid // FF // Katech Drop-In // PLM Heat Exchanger // ZLE Cradle bushings // BMR Chassis-Suspension Stuff // aFe Bars // Diode Dynamics LEDs // ACS Composites Guards // CF Dash // Aeroforce // tint // other stuffs |
07-11-2009, 10:16 AM | #12 |
Go Blue!!!!!
Drives: 2012 Cruze LT Join Date: Mar 2009
True, but if your dealer says they are voiding your warranty for whatever reason regardless, then you are the one who has to prove that the modification did not cause the problem. That means you getting a lawyer and spending money. It's all on you the car owner.
07-11-2009, 10:18 AM | #13 |
Go Blue!!!!!
Bottom line is some of the L99's are not performing as advertised. GM should provide a reflash to the computer(this is the problem, the tune) free of charge to the buyer to get the performance advertised.
07-11-2009, 10:26 AM | #14 | |
Petro-sexual
I guess I'm just saying I agree that it shouldn't take so much effort to have a 400 horse' car run like a 400 horse' car should. I know exactly how bad TM can hurt the car's performance (my car would go bonkers after the TC install if the TM wasn't removed). Hopefully there's something positive that comes out of this for the L99 guys
Similar Threads | ||||
L99 w/ American Racing Headers & Tune...I got your 0-60 right here. | pharmd | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 41 | 01-28-2013 04:48 AM |
Independence Day | patriotpa | Off-topic Discussions | 7 | 07-05-2009 06:24 PM |
"...in the eleventh hour of the eleventh day..." | fbodfather | 5th Gen Camaro SS LS LT General Discussions | 51 | 11-12-2008 08:40 PM |
AutoCross and Pedders Day Sept 15-16 | Info@PeddersUSA.com | Off-topic Discussions | 4 | 09-03-2007 12:26 PM |
