Old 08-25-2016, 08:11 AM   #1
Rdunn
Really, Really Fast
Rdunn's Avatar
Drives: 2010 Camaro SS
F1X Camaro getting some upgrades
Currently the car has a built 429ci Stock block LS3 (4.125 stroke x 4.070 bore) but it was at the limits of everything powerwise (around 1100rwhp) set up ran great for 2 years under lots of abuse from track and street racing. I recently sold the shortblock and it will be going to live out the rest of its days in another car.
car ran really consistent low 9s. but like every power level. that starts to feel slow. So yesterday I order a LSX block, wiseco pistons, oliver rods and a magnum crank. I will finally be able to use the F1X blower to its potential, instead of only being able to run 22psi of boost.
new motor will be a 427ci. and i will be reusing the PRC260 heads that were on the last motor.
cant wait to get it running again and make some passes.
Procharger F1X, TH400, E85, CBI Street Cars, DSX Tuning, 1300whp
Rdunn is offline   Reply With Quote
Old 08-25-2016, 08:16 AM   #2
bct10985
Drives: 2010 2SS LS3, 2013 duramax
How much more will the f1x make?
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 08-25-2016, 08:37 AM   #3
TOSTO RACING
STOCK ELIMINATOR
TOSTO RACING's Avatar
Drives: STOCKER
Should be wicked! Good luck on getting it going. I see some 8 second passes soon!
5664 AA/SA
1970 NOVA
TOSTO RACING is offline   Reply With Quote
Old 08-25-2016, 10:47 AM   #4
Rdunn
Really, Really Fast
Rdunn's Avatar
Little over 30.
Old 08-25-2016, 11:05 AM   #5
swiftkart
swiftkart's Avatar
Drives: 2010 SS/RS LS3 M6
Following, can't wait to hear the new results!
swiftkart is offline   Reply With Quote
Old 08-25-2016, 04:48 PM   #6
DarkCry956
DarkCry956's Avatar
Drives: 2011 Camaro 2SS/RS
That's gonna be nice!!! What spark plugs were you using on your old setup?
DarkCry956 is offline   Reply With Quote
Old 08-26-2016, 09:53 AM   #7
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
following this, can't wait to see what you get out of it! Good luck. Whats your ETA on completion for your new setup?
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 08-26-2016, 10:07 AM   #8
Bildo
Bildo's Avatar
Drives: 2012 2SS/RS LS3
Doing an ERL 427 with PRC 255's and an F1A / E85 right now once I redo from the tranny back I am hoping to squeeze the F1X in for a head unit upgrade. Let me know how much massaging you need to the strut tower to get that bad boy to fit.
Bildo is offline   Reply With Quote
Old 08-26-2016, 10:40 AM   #9
bct10985
He already has the f1x in there. I remember seeing pictures, search his profile
Old 08-26-2016, 10:57 PM   #10
Rdunn
Really, Really Fast
Rdunn's Avatar
We cut a hole about the size of a softball in it, to make the f1x fit
Old 08-27-2016, 11:07 AM   #11
hillshooter
Drives: 2015 Camaro SS commemorative
I am following this for sure. Keep us up with all the juicy details.
Procharger FTW!
hillshooter is offline   Reply With Quote
Old 08-28-2016, 11:48 AM   #12
D3R3K
Sittin side ways
D3R3K's Avatar
Drives: 2010 2SS/RS IOM
We have a local f1-x vette that makes 1600rwhp with a LME 427. I want to put the f1-a/94 in mine.
850+hp club member
Procharger F1-A
D3R3K is offline   Reply With Quote
Old 02-02-2017, 11:01 AM   #13
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
any updates?
2018 Camaro SS A8 Edelbrock 2650 FBO 93 octane 9.54@144 Pump E 9.59@152
2010 Camaro
Stock bottom end with 46,000+miles JRE remote tuning Whipple A6 and Drive it to and from the track 9.46@146
94guy is offline   Reply With Quote
