11-30-2016, 09:00 AM | #1 |
Oil cooler failure/leaking.
So is the oem oil cooler known for failure/leaks?
Someone bought my old cooler because if theirs failing. Didn't know if this was common because if it was I'd like to get something started so GM knows of a design flaw.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/ |
11-30-2016, 10:37 AM | #2 |
Drives: Black 2SS RS w/White Stripes Join Date: Mar 2011
Yes I have heard this is an issue. While mine has not started leaking yet(knock on wood) I have heard that many of them do. In fact when I had my car at lethal a few years back they said my car was the first one that came in and the cooler was not leaking. I have also heard that it is not a very effective cooler either.
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods | Installed by Me & Tuned by Pat G |
11-30-2016, 12:16 PM | #3 |
Drives: 2010 camaro ss Join Date: Jun 2010
Yes mine was leaking. Changed the gasket and still leaking.
11-30-2016, 12:20 PM | #4 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
Mine did, L99, and was fixed under warranty and zero issues since. I may have had about 23k miles on it.
11-30-2016, 01:20 PM | #5 |
Drives: 2011 Camaro 2SS/RS Join Date: Oct 2011
You have an iron 6.0 like I do. I had to install an oil cooler with a fan to keep from heating up when daily driving. I have the stock one somewhere in the garage
11-30-2016, 01:54 PM | #6 |
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro Join Date: Oct 2013
11-30-2016, 02:18 PM | #7 |
Took mine off almost 2 years ago.
11-30-2016, 03:43 PM | #8 |
Drives: 2023 Camaro ZL1 1LE Join Date: Feb 2016
Was there even much of a difference in oil temps after taking it off?
2014 Camaro SS Spring Edition LSX440ci
LSX Block, MAST 305 Black Labels, Exceldyne Valves, Diamond Pistons, Callies Crank & Rods, Cam Motion Cam, Johnson 2116LSR Lifters, Comp XDA Pushrods, Jesel Rockers, Mamo MSD, NW 102, Roto-Fab CAI, FAST 65# Injectors, ZL1 Fuel Pump, Kooks 2" Headers, Corsa Sport 3" Catback, Z28 Shifter, ZR1 Clutch, Katech LW Flywheel, 1LE 3.91 Diff, LPW Diff Cover, BMR - 1.4" Springs, LCA's, Trailing Arms, Toe Rods, Sway Bars, End Links, Diff Bushings, and Tunnel Brace, Z28/1LE Strut Tower Brace, Improved Racing Oil Cooler 2023 Camaro ZL1 / 1LE Stock |
11-30-2016, 04:06 PM | #9 |
Takes longer for the oil to warm up.
11-30-2016, 07:10 PM | #10 |
So eliminating the oil cooler makes it warm up slower?
11-30-2016, 08:02 PM | #11 |
That's what the factory piece is there for imo. To warm up the oil quicker for emissions
11-30-2016, 08:50 PM | #12 |
Drives: 2010 2SS M6 Join Date: Nov 2012
Had mine fixed under warranty 3 years ago and haven't had a problem since. They put a new cooler on and all new gaskets along with a new oil pan gasket cause that was leaking also.
Mods: SW Retro Chambered cat back, CAI cai black, APEX scoop and ww tank, RX catch can, APEX Skip-shift Eliminator, Hurst short throw, Speeddawg knob, Kooks 1 7/8 headers high flow cats, BMR trailing arms and toe rods, Livernois dyno tune, ZL1 grill and side skirts.WHP: 415 WTQ: 407
12-01-2016, 10:49 AM | #13 |
Drives: 2012 2SS/RS LS3 Join Date: May 2012
Delete it. I have a thread on my experience.
Victory Red 2012 2SS/RS LS3 Camaro
Pat G. Spec Cam from Cam Motion 228/236 .599/.599 112+2LSA Kooks 1-7/8" LTs w/ Cats Roto-Fab, Bo White TB, Borla Touring Catback 3.91 1LE Gears, MGW Tuned by Pat G |
12-01-2016, 01:20 PM | #14 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
My cooler leaked and ultimately broke and oiled a track down.
Fixed under warranty, but I pulled it off and gave it to BH.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
