02-10-2017, 06:00 PM | #1 |
SS4 GPI/Frankenstein Combo!
02-10-2017, 06:05 PM | #2 |
Drives: Savitar; The 500rwhp N/A Monster! Join Date: Aug 2016
Sounds wicked man
*SOLD*504HP/433TQ | Night Fury cammed Cold Air Inductions intake Bo White ported TB Speed Engineering 1 7/8 longtubes NPP catback QTP low profile cutouts Powerbond 25% UDP 3.73 gears JRE scoop ZL1 grille R1 Concepts drilled/slotted rotors built/tuned by Weapon X Motorsports
02-10-2017, 06:28 PM | #3 |
Drives: 2011 ss 2ss auto camaro Join Date: Mar 2015
Sounds really good . Clean car.
02-10-2017, 08:28 PM | #4 |
Engine pic.
02-10-2017, 08:43 PM | #5 |
'It's an experiment'
Purdy!
-Don
747 RWHP 794 RWTQ
02-11-2017, 07:16 AM | #6 |
Looks and sounds great!
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
02-11-2017, 11:19 AM | #7 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Love the engine bay. Clean, simple, and reeks of pure NA power!
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
02-11-2017, 12:10 PM | #8 |
02-11-2017, 01:35 PM | #9 |
Kooks all the way!
02-11-2017, 01:50 PM | #10 |
02-11-2017, 03:16 PM | #11 |
Engine bay is all business
02-11-2017, 03:19 PM | #12 |
Drives: 2013 1LE/SS Join Date: Mar 2012
Sounds great? Are you running the new vararam intake?
Current mods: Stainless Power Long Tube Headers,Cat Delete,CAI Cold Air Intake,Vitesse throttle controller, Muffler/Resonator Delete w/dual tips. ADM Performance Tuned,BMR 1.25 lowering springs,R1 Concept Slotted/Dimpled Rotors.
02-11-2017, 04:30 PM | #13 |
Thanks Bo! C7 fest going to be awesome.
Yes, that is the new one.
02-11-2017, 04:35 PM | #14 |
Sounds simply amazing.
That is one gorgeous engine bay. Very clean. Fantastic work!
2010 CGM Camaro 2SS LS3 Swapped A6 - GPI LS3 SS1 .647/.638, (224/237, 112 +4, 7Ί overlap) on CamMotion 8620 core, BTR Platinum .660" Dual Spring kit w/titanium retainers, CHE bronze trunnion upgrade, stock heads milled @ .015, Melling HV 10296 oil pump, TSP 1-7/8" long tube headers (W/Catless Off-road Pipes), Corsa Xtreme 3" Catback, GPI Ported/Rod Mod Intake, Stage 2 Ported Throttle Body, Vararam OTR CAI, Mike Norris Gen 2 catch can + GM 1LE clean side separator, 160Ί thermostat - Megan Racing adjustable coilovers (lowered 1.75"), MRR M017 10/11" wheels-Tuned by Ryan @ GPI
