Old 02-19-2017, 01:30 PM   #1
StreetOutlawLS3
StreetOutlawLS3's Avatar
Drives: 2013 Camaro SS LS3
Thoughts on F1X 416 M6 build?
Just as title says what are your thoughts on a 416 using ls3 block all forged internals, running a f1x pro charger? I'm looking for 1000+ hp would be happier with 1100+ hp.
Would the ls3 block hold up well? I'm sure it would be smarter to go with a LSX block but would love to keep the ls3 block and run the procharger.
2013 1SS LS3 M6 - ZL1 (3.73) differential kit - Street Slayer Twin Disc - Cam Motion cam 228/236 spec'd by Patrick Guerra - C5r timing chain - manton pushrods - BTR dual .660 valve springs - TSP 1"&7/8 LT's(no cats) - 3" Hooker Black Heart axle back with 4" quad tips - MGW flat stick shifter - tuned by Patrick Guerra @LSX performance dyno tuning - 305/45-18 MT ET Street
StreetOutlawLS3 is offline   Reply With Quote
Old 02-19-2017, 02:27 PM   #2
AGP Turbo
Drives: All things Turbocharged
F1X can totally make 1100whp BUT that is questionable on an aluminum block. I would say "holds up well" at about 1000-1050whp. But sure to overdrive it and wastegate for boost control. This will get torque up and have it in the power better every time you shift. That's one of the big complaints on centri M/T cars.
AGP Turbo is offline   Reply With Quote
Old 02-19-2017, 02:27 PM   #3
bayarea408
bayarea408's Avatar
Drives: T
if i were you and had plans for over 1k regularly. Iron Block/ Twin Turbo. Most turbo kits these days can be had cheaper then blower kits, and make more power. If you use certain controllers you can boost by gear adjust it all to work properly.
In my opinion if you stay under 1k hp forged Aluminum ls3 is ok.
Over 1k hp I would consider an Iron block
bayarea408 is offline   Reply With Quote
Old 02-19-2017, 04:56 PM   #4
DarkCry956
DarkCry956's Avatar
Drives: 2011 Camaro 2SS/RS
Rdunn had a similar setup for a long time. 429ci stock block on a 4l80. 1000+hp
DarkCry956 is offline   Reply With Quote
Old 02-19-2017, 07:03 PM   #5
ecreps
Drives: 2014 1LE, 1996 z28
What heads are you planning to run? I think you will want some pretty thick heads if sticking with a 4-bolt setup.
Other than that it should run well.
ecreps is offline   Reply With Quote
Old 02-19-2017, 08:34 PM   #6
Bildo
Bildo's Avatar
Drives: 2012 2SS/RS LS3
I am doing similar right now, but not a stock block, ERL 427 w/F1A planning on going to the F1X once a transmission and rear end setup are in the budget.
Bildo is offline   Reply With Quote
Old 02-20-2017, 12:59 PM   #7
DYNAMIC RON
Drives: 2015 CAMARO SS RS 1LE
My Scat crank is flexing @ aprox 800 Crank HP. #2 & #4 main bearings (ACL). Nothing broke, just tore it down for inspection. If you dont mind the weight i would suggest a iron block.
DYNAMIC RON is offline   Reply With Quote
Old 02-20-2017, 02:41 PM   #8
hillshooter
Drives: 2015 Camaro SS commemorative
is that with ARP on the mains? that seems like a very attainable HP on a stock short block, let alone a built one.
hillshooter is offline   Reply With Quote
Old 02-21-2017, 07:55 AM   #9
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
Hope you got your engine, or at least ordered it. ERL is exiting the car engine business as of now.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000,
realcanuk is offline   Reply With Quote
Old 02-21-2017, 11:04 AM   #10
EvilZL1
Snake Eater
EvilZL1's Avatar
Drives: 2012 AGM ZL1
Wait what? Where are you reading this???
Build Thread: http://www.camaro5.com/forums/showth...95#post8351295
Make sure you don’t forget to subscribe to my channel! More content on the way. Like, share with your friends
https://www.youtube.com/channel/UC9Z...sP2wjsLLFeP1zQ
Follow me on instagram:
http://www.instagram.com/snkeatr/
EvilZL1 is offline   Reply With Quote
Old 02-21-2017, 11:06 AM   #11
realcanuk
realcanuk's Avatar
Look at their website....
Old 02-21-2017, 11:25 AM   #12
EvilZL1
Snake Eater
EvilZL1's Avatar
Just did wow. Didnt think that would happen. Guess dart block it will be from now on
Old 02-21-2017, 12:33 PM   #13
Bildo
Bildo's Avatar
Yeah I have had possession of my block for over a year, but definitely not happy they are closing. Found out yesterday they sent me the wrong sized ARP bolts for the top of the cylinder in the head stud kit. Called them and they insisted I send back the wrong ones before they would send me the correct ones. Kinda pissed me off I spent 11k on a shortblock including the head stud kit and they want to play the game instead of give me what I paid for over $24 worth of bolts on a 11k sale.
Old 02-22-2017, 09:12 AM   #14
Rdunn
Really, Really Fast
Rdunn's Avatar
Drives: 2010 Camaro SS
Only thing I did to mine was pin the mains and ran ARP everything. stock block held great at 1100hp and is still running strong 3 years later ( just in a different car)
the F1X is a great blower that will handle anything you want to throw at it. I have a LSX block in mine now and running 30 pounds of boost thru it with the X
Procharger F1X, TH400, E85, CBI Street Cars, DSX Tuning, 1300whp
Rdunn is offline   Reply With Quote
