Old 04-01-2015, 11:26 PM   #1
bigwayne3000
Drives: 2011 Camaro LS
Question about struts
I failed PA inspection because my front right strut is leaking so it needs to be replaced. I know you should replace them in pairs so my question is this... My car is a 2011 with a little over 80500 miles on it. Should I just go ahead and replace all 4 of them instead of just the fronts? I'm buying some Monroes off Rock Auto for half of what it'd cost me to buy ones from Auto Zone so I can pretty much do the entire car for the price of having just done the front if I bought them at Auto Zone. What would you all recommend?
Also, this is the cart for my Rock Auto purchase, do I have everything I need? Do I need to buy new bellows for them or can I reuse the old ones?
bigwayne3000 is offline   Reply With Quote
Old 04-01-2015, 11:56 PM   #2
bigwayne3000
Well, I went to the Monroe site and the part #s match up and so does the list of items I need. I'm still curious if I need a new bellow/boot though and if I should just go ahead and do all 4 or just stick to doing the fronts.
Old 04-02-2015, 12:02 AM   #3
Candr3535
Candr3535's Avatar
Drives: 2013 ZL1 Triple Black Vert M6 #5591
I would just do the fronts. My opinion
695 RWHP / 660 RWTQ @ 13.5 PSI
Dyna-Tech Headers Ceramic Coated w/Super Flo Cats, JRE Custom Rough Idle Racing Cam Package and 125 RWHP Pulley Kit w/ 28% pulley, Custom Tune by Ted, ID850 injectors, JMS Fuel Booster, NGK Plugs, MSD Plug Wires, Roto-Fab CAI, Roto-Fab Big Gulp, Elite Catch Can, Mild to Wild, 90mm VMaxx Ported Throttle Body, Skip Shift Elim., D3 Coolant Resevoir, Separated Clutch Resevoir, and Fuzzy Red Dice..
Candr3535 is offline   Reply With Quote
Old 04-02-2015, 12:26 AM   #4
bigwayne3000
Ok thanks. Rock Auto prices are dirt cheap and I have to do my front right hub assembly and front rotors/brakes so I'm already spending a bit. I guess I will hold off until I need to do the rears. There is a promo for Monroe going on but it isn't worth spending money to save money right now. If I didn't have all this other work I'd probably just do all 4. Thanks.
Old 04-02-2015, 10:40 AM   #5
aFe POWER
aFe POWER's Avatar
Drives: Camaro
If you can do KYB's. I have a set on one of my cars, the excel-G/GR-2 series shocks and struts have a lifetime warranty. I already had a passenger front leak and it got replaced for free exchange, as long as you keep the receipt on hand.
aFe POWER is offline   Reply With Quote
Old 04-02-2015, 01:07 PM   #6
BMR Sales
BMR Sales's Avatar
Drives: Race Car
I've got Koni's on sale 25% Off - set of 4 go for $402.80
Old 04-02-2015, 02:51 PM   #7
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
My brother has a set of Koni Oranges he just took off for coilovers, i'm sure he'd sell them for a good price.
The tire setup he was running in the front rubbed on them, but if you have stock size tires they will work fine. They were only on the car one-week.
PM forum member Moonchopper if you're interested.
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 04-02-2015, 06:11 PM   #8
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
I suggest doing all 4. Shocks/struts are only meant to go 40-60k miles before they start losing their damping.
Best regards,
Tyler
888-308-6007
Old 04-02-2015, 06:36 PM   #9
Wacko37
Wacko37's Avatar
Drives: 2010 2SS/RS & 2007 2500HD D-Max
is the $402.80 the sale price? my car has 55k on it and im starting to race/beat it so im sure it will be happy to get some new shocks/struts!
2010 Summit white SS/RS, Manzo full exhaust w/2" primaries, Roto-Fab intake, FE4 conversion, JRI Coilovers built by Ult_Performance w/hypercoils, BMR sway, BMR trailing arms, UMI toe links, solid sub-frame bushings, upper control arm bushings, radius inserts, caster locks, Taylor wires, BTR spec'd cam, tuned by ECS, various little lighting mods, ebay SLP splitter, Heritage grille, ZL1 rockers, Apex 19x11 w/RE-71r's 305/30/19, eaton tru-trac
2007 2500HD Duramax, Built trans, custom tuned beast
Wacko37 is offline   Reply With Quote
Old 04-03-2015, 07:58 AM   #10
Destructo09
Yeah that should be the sale price, mine were 405 with 25% off.
I think you should be fine with that wheel tire combo and the Koni's, 20x9 +40mm tires and 275/40s don't fit with the Koni Oranges, but since you have +23 20x10s I think you'll be fine, you should have the same backspacing I do with a 20x9 and 5mm spacer. It's really tight, but doesn't seem to rub much.
2010 2SS
BMR 1" Springs
1LE rear sway bar
SRP Racing Pedals
K&N Typhoon CAI
