12-15-2011, 03:41 PM | #1 |
Chiquita
Drives: 2013 1LE/1SS YELLO1LE 1 of Only 28 Join Date: Nov 2011
DRAG STRIP TRICKS
This sumer I'd like to take my car to the drag strip. Any tricks for a beginner? I have a 6 speed stick and a v6 I'm all ears. If I posted in the wrong AREA PLEASE MOVE me I don't know how to move once I have it Posted
12-15-2011, 03:43 PM | #2 |
Drives: Silver 1LT 2011 camaro Join Date: Jul 2011
No tips but you should probably remove everything before the coma.
12-15-2011, 03:43 PM | #3 |
Anabolic Connoisseur
Drives: Sold - Blown Camaro 2SS/RS LS3 Join Date: Sep 2010
12-15-2011, 03:46 PM | #4 |
it's mind bottling..
Drives: SGM Join Date: Apr 2011
timing is everything
12-15-2011, 03:47 PM | #5 |
Probably better to remove it and just be "this sumer I'd like to take my car to the drag strip. Any tricks for a beginner? I have a 6 speed stick and a v6 I'm all ears."
12-15-2011, 03:54 PM | #6 |
Drives: 2011 1LT Join Date: Jul 2011
I've personally never raced a car at a track, but I've heard to keep the gas at a quarter of a tank to preserve weight. I'm not sure if it would even make a difference or not honestly, but I remember reading that on here at one point.
12-15-2011, 03:56 PM | #7 |
by Odeon
Drives: '12 SS/RS A6 IOM SOLD, '13 1LE IOM Join Date: Nov 2011
Clutch upgrade is in order if you're going to be doing this a lot.
"It works 60% of the time, every time."
"Some say it's a waste of time, others say it's an incredible waste of time." "The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands at times of challenge and controversy." 2013 IOM SS/RS - 1LE. Born 5/6/2013 (1 of 32 1SS IOM 1LE's) |
12-15-2011, 03:56 PM | #8 | |
ace5.org
I'd suggest comma.
Stock...For Now.
12-15-2011, 03:57 PM | #9 |
Drives: Really Slow Join Date: Apr 2010
you can lose some air in your rear tires for more traction. understand how the christmas tree works, where you're going.
12-15-2011, 04:25 PM | #10 |
Drives: 2010 2SS IOM L99 Join Date: Jan 2010
practise,practise,practise.
12-15-2011, 04:29 PM | #11 |
TRI COUNTY TAMPA
Drives: 2011 1SS/RS VR/BLK A6 Join Date: Jan 2011
Here is my first tip. You will not have any vehicle damage insurance from the starting line until you get onto the return road. Keep this in mind before you go. You gotta pay to play.
Next tip. I assume you will be on street tires. So lower the rear pressure down a a few lbs and DO NOT run through the water box then burnout. Next try a run with all the nannies on to get the feel of it. The track is nothing like a normal paved road. Last tips. Pay attention to the guys working the track. Pull forward until the top pre-staged lights come on. Roll slightly forward until the staged lights come on. When tree starts then launch when the 2nd yellow light comes on (unless a pro tree). After the run try to avoid turning off on the first turnout and rather go to the end turnout. Also if in left lane NEVER turn off in front of the person in the right lane. FINAL TIP. Post this in the drag racing section instead of here. |
12-15-2011, 07:24 PM | #12 |
40 pounds front and 25 pounds rear in the tires, low on gas, ditch any trunk junk, don't worry about taking off on green light, hold RPM at 2.5-3K and let up clutch pedal in one motion, don't dump it slip it out.
2011 Black 1SS M6 12.75@110.91 bone stock
Now: Coated Dynatech LT's/!Cats/Hurst Shifter/Roto-fab/SLP SS badges/JRE 415HP Tune, Scoop & Washer Relocation Bottle,Hurst Stunner 20X9 Wheels, Moroso Catch Can, ASP pulley, Magnaflow X-pipe, GTO remote clutch reservoir 1989 Silver 5.0 Mustang LX Coupe 1999 Pewter Tahoe LT 2011 Blue Camry SE |
12-15-2011, 08:14 PM | #13 |
502 RWHP N/A
Drag radials or slicks, also go before green by the time u hit the pedal it will be green
factory motor factory trans, Gpi ss4 cam stock heads ported and milled, full exhaust, circle d 5c 4000 triple disk, 3:91 rear end with posi mod, cai, bmr derlin rear diff bushins, bmr derlin cradle bushins, bmr trailing arms, toe rods with bushings, and bmr anti extreme sway bar. Weld rt-s 17x5 fronts and 17X10 rears on mickey thompson et street r's
12-17-2011, 03:12 PM | #14 |
Drives: 2005 C6 Join Date: Apr 2011
Similar Threads | ||||
Hey, Oklahomans, let's go to the drag strip in Tulsa (Last Weekend Before Closing)! | BowtieBelle | USA - Southcentral | 9 | 10-20-2011 02:14 PM |
First time at the drag strip (ever) | Three of Swords | Dragstrip and Launch Techniques Discussion | 25 | 10-04-2011 10:58 PM |
Englishtown Drag strip T&T night | Sammy2010SS | USA - NY / NJ / PA | 2 | 08-12-2010 05:09 AM |
Just got back from the drag strip... | camarokid1998 | Dragstrip and Launch Techniques Discussion | 5 | 09-24-2009 06:43 AM |
Had the V6 at the Drag Strip | Big Thunder Performance | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 23 | 06-11-2009 09:30 PM |
