Old 02-16-2012, 05:26 PM   #1
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Drives: A 2016 Challenger R/T M6 STP
Post TRACK DAYS: Break & Differencial oil change needed for Lapping?
HI Guys,
This year I'm doing a lot more track days.
Perhaps once every 2 weeks for at least one hour each time.
I'm also planning to go to 3 full day Time Attack, each can be about 2 to 3 hours of track time.
Questions:
1) When do we need to replace the DOT3 break fluid to higher specs one? if so which kind?
2) When do we need to replace the OEM Differencial fluid to GM higher specs one?
3) Anything else needs to be done to the SS for track days? I'm not talking of modifications here, just maintenance et prevention of existing oem parts.
If you have any experiences regarding this subject, please inform me.
Thank you in Advance.
Mik
Track Day Videos: http://www.youtube.com/user/mrgoodman2000/videos
Built #83817, Born January 18th, Christened June 11th 2010, Stolen October 3rd 2016.
Mikamaro is offline   Reply With Quote
Old 02-16-2012, 08:00 PM   #2
Phat Ralph
Phat Ralph's Avatar
Drives: 2011 Camaro 2SS/RS 6spd Synergy
Originally Posted by Mikamaro View Post
Questions:
1) You can use a DOT3 or DOT4 fluid. Change fluid out about as close to the track day as possible. I use Motul, but any high boilling point fluid will do.
2) Change your rear differencial fluid before you track your camaro. And change after every two track day events. I use Amzoil with a additive.
3)I would recommend changing your brake pads to a good high performance pad. Change Brake fluid. Change Differencial fluid. A seatbelt lock is a plus.
Have Fun! It is amazing what these cars will do in stock trim!!!
2011 Camaro RS/SS Synergy - (Pedders Xa's Coilovers, ZL1 Sways, SS Brake Lines & Bushings), Hotchkis Chassis Brace & Strut Bar, DSS 1000hp Road Race Axles, Nitto NT-01's, TSW Wheels, ADM CAI, Borla ATAK, HAWK, Granatelli Rotors, Barton Shifter, Tick Performance Clutch Line, MRS Exhaust Tips, Elite Catch Can.
Phat Ralph is offline   Reply With Quote
Old 02-16-2012, 09:49 PM   #3
boltvette
boltvette's Avatar
Drives: 1963 Corvette, 2001 Corvette
I agree with the brake fluid change. And you should change your oil after every second track day at a minimum. Not sure that you need to be changing the diff fluid that often, but it can't hurt. If you are going to stay with the stock seats, look into Angel Pads at www.angelwingstech.com. They will give you the lateral support that the stock seats sorely lack.
2-seater "Camaro" w/JMS Racing LS3; C5 Z06 trans; C6 ZR1 exhaust; Dynatech catback; Ron Davis radiator; trans, diff & engine oil coolers; Pfadt JOC Stage 1 bars & shocks; C6 Z51 brakes; Angelwings C5 Track Day Bar; Angel Pads!
boltvette is offline   Reply With Quote
Old 02-16-2012, 10:01 PM   #4
DandD
DandD's Avatar
Drives: 2010 2SS and 2011 LS
I believe the change interval on the diff fluid is every 7 hours of race time, I will confirm that and post it up
Around here we like baseball, hot dogs, apple pie, and Chevrolet
DandD is offline   Reply With Quote
My V6 oil change experience convert Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 38 04-08-2014 04:15 PM
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 08:51 AM
8500 mile oil change interval (5w-30) oil (not synthetic oil) 2001ragtop General Automotive + Other Cars Discussion 0 01-18-2012 09:06 AM
Major U.S. oil source is tapped KILLER74Z28 Off-topic Discussions 32 10-30-2007 09:47 AM
