Old 05-15-2010, 09:38 PM   #1
Becustom
ProCharged 600 + RWHP
Becustom's Avatar
Drives: 2SS/RS White/Hugger Orange
Axles joints ?
Are the stock axle joints a problem or is it just the shaft.
I am asking because I'm getting grease on my left wheel. I have to check it out tomorrow , But the boot must have a problem. It still drives fine with no noise .
Becustom is offline   Reply With Quote
Old 05-16-2010, 12:58 PM   #2
ChevyThunder
Drives: pinto
If you are losing grease from your CV "constant velocity joint" you need to stop driving the car and get the problem fixed . Here is what the insides of that joint look like and what the grease is lubricating
The more grease you lose out of the joint the more friction and eventually the joint will fail. As it is you may have already compromised the life of the CV.Your boot is either torn or has slipped off the CV
Also.. be sure the grease is coming from the CV and not somewhere else
ChevyThunder is offline   Reply With Quote
Old 05-17-2010, 06:39 PM   #3
carriagehousecustoms
Drives: 1ss american iron
We lost an axle last weekend just for this reason, Lost the boot and the cv failed, The boots are not very good, we had some new boots shipped out from the drive shaft shop and so far so good. 160 mph is not good for the stock boots.
Dave
carriagehousecustoms is offline   Reply With Quote
Best Deal on DSS Camaro 2010 - 2011 Axles Paschal Performance Transmission / Driveline 8 09-18-2010 11:23 PM
Hot Deal For DSS 2010 Camaro Axles Paschal Performance Transmission / Driveline 3 03-04-2010 08:36 PM
1,000 HP Extreme Duty Rear Axles and CV Joints Package SpohnPerformance V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 31 02-24-2010 10:50 PM
Gforce Engineering axles and driveshafts coming soon GFORCE1320 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 13 02-13-2010 11:29 AM
NEW Driveshaft shop High output axles! IPS Brandon V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 18 09-19-2009 02:38 PM
