Old 09-09-2016, 08:15 PM   #1
Top Off
Drives: 2012 LS3 1SS/RS Vert
Another will it fit?
Looking at the reproduction ZL1 wheels 20x10 +35 for all 4. I'm lowered with the Pfadt 1.25 springs. I'm a little lower due to the extra weight of the convertible. I would like to run 295x35, since I think the 285x35 is just to low at this point. Am I dreaming of the 295 fitting and need to stick with the 275x40?
I checked a bunch of threads, but did not see this combo.
Thanks in advance
Top Off is offline   Reply With Quote
Old 09-16-2016, 01:32 PM   #2
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
Ride height shouldn't be an issue. There shouldn't be much difference between a 295 and a 285 of the same series. The 275 will likely be about the same, maybe slightly larger.
For example:
285/35 : 27.9"
295/35 : 28.1"
That's .1" difference in ride height.
The issue, if any, would be rubbing (on the fronts) with a 295 (with that wheel offset).
JimE is offline   Reply With Quote
Old 09-16-2016, 03:42 PM   #3
Need4speed_motorsports
Need4speed_motorsports's Avatar
Drives: 2016 Camaro SS
The fitment isnt a issue but the 295 is too much
275/40/20 is perfect.
Need4speed_motorsports is offline   Reply With Quote
