03-12-2018, 11:19 AM | #1 |
Ported Throttle Body Suggestions?
I'm looking to get a ported throttle body and need suggestions on what and where to get it. I have an L99 2010 SS.
03-12-2018, 11:29 AM | #2 |
Drives: 2010 Camaro 2ss/Rs Transformers Join Date: Aug 2014
What size are you going for? If you want to use your stock throttle I know you can send that out to be ported. I have a Nick Williams 102mm throttle body and works perfectly. I used to have a BBK 102mm throttle body. But I always had trouble with it so took it off and wouldn’t use a BBK throttle body again. I know BBK also makes a 95mm throttle body which is still bigger than stock. You’ll need a bigger intake manifold to use the 102mm throttle body as well. You can check phastek. If you go bigger than stock you’ll most likely need a tune/retune. Not sure about porting the stock throttle body. Hope this helps!
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage LS3 conversion Vararam intake(tune model) Kooks LT headers & cats delete Corsa ZL1 3" exhaust RedBarn Racing Tune CMS Stage 3 Cam AFR CNC ported heads MSD Spark plug wires LNC-2000 Launch controller NGK TR6 Spark Plugs 1le strut tower brace-TPIS spacers Nick Williams 102mm throttle body Fast lsxr 102 intake manifold Slp 25% UDP Katech Tensioner Pulley Circle D 3600-3700 multi disk Stall GM 3.91 gears DDS carbon fiber driveshaft ZL1 fuel pump & injectors Flex fuel sensor(91/E85) https://wheelwell.com/kris-perez |
03-12-2018, 11:35 AM | #3 | |
I don't have one yet, but that is definitely where I will be getting mine. The support you will get through Bo would be worth it for me, as he is a frequent forum poster and is VERY knowledgeable. I am not sure you will get that kind of support/access with a Vmax unit. But I do hear good things about them too.
03-12-2018, 11:41 AM | #4 | |
03-12-2018, 11:50 AM | #5 | |
No problem! One of the problems I had with the BBK was surging and also getting cels that came up after clearing it then driving miles later. I suggest getting your stock throttle body ported by Bo white. I’ve heard only good things. I don’t think you would need a tune, but not 100% sure.
03-12-2018, 11:55 AM | #6 |
Drives: 2011 1ss Join Date: Jun 2017
I got a ported throttle body coming in from Bo White this week. Looking forward to putting it on
03-12-2018, 12:00 PM | #7 | |
03-12-2018, 02:53 PM | #8 |
Drives: 2015 Camaro 1SS L99 Join Date: Apr 2016
I would recommend Bo white or VMAX. Bo seems to have a little better reputation around these parts, but he doesn't (or didn't when I ordered) take core returns. VMAX will give you $150 off if you send your core in. Both seem to have good reviews here on C5 - but that core charge makes VMAX $150 cheaper just sayin
03-12-2018, 02:57 PM | #9 |
Drives: 2014 Camaro SS L99 Join Date: Nov 2017
+1 For Bo. And you can still sell your stock TB on here. Sold mine for $120 shipped.
MODS: GPI MAX Package ported and milled heads+(229/250,111 LSA),Johnson 2110 Lifters,BTR .660 Springs,CHE Trunnions,C5R chain,DSX Flex Fuel kit,LSA Injectors,ZL1 Fuel Pump,MAMO Ported MSD Intake manifold,BOWhite ported Throttle body,25% UDP,CAI Intake,Intake Scoop,Kooks 1 7/8 headers,Borla attak catback,Elite catch can,BMR Motor mounts,CircleD 5C 4000-4200 Torque converter,ADM trans cooler,Jannetty Trans dipstick,DSS Aluminum Driveshaft,3.91 Gears,Eaton TrueTrac,JRE Billet caps,BMR Trailing arms,BMR Toe rods,BMR rear sway bar,Pegasus Solid sub frame bushings,DSS 1,000HP Axles
03-12-2018, 04:39 PM | #10 |
Drives: 2013 SS Convertible, ThumperII Join Date: Nov 2016
I gotta go with Bo White also.
03-12-2018, 04:50 PM | #11 |
Drives: 2010 Black 2ss Camaro SS Join Date: May 2010
+1 on Bo White
ZL1 10 spokes,Dart 388,ECS Supercharger 2200x, E85 Flex Fuel sensor, Dart 388 , B&M Tranny Cooler, Vigilante 4000 Triple Disc TC,Katech Ported Heads, Texas Speed Sheet Metal Intake, ECS Big Blower Cam,ID 1700s, Fore Triple Pumps, E85,ATI Super Dampner, KW V3 Coilovers, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 Rear Diff, RPM 6l90e level 10 Tranny, SW Long Tubes no cats,Nick Williams Boosted 102mm TB, Dr Phil Tune,Borla Atak
03-12-2018, 05:15 PM | #12 |
Bo White is good to go, also check out Pray Performance, his porting work is top notch! Can't go wrong with either one, IMHO.
-Scott |
03-12-2018, 05:23 PM | #13 |
No tune will be needed if you port your oem throttle body. You can do it yourself simply or send it to Bo. You will get better throttle response from porting it.
Car mods: never enough!
03-12-2018, 05:38 PM | #14 | |
Drives: 2015 1LE Join Date: Oct 2015
I did the VMAX and it seemed to work, I dont know how accurate the video is so you be the judge. |
