#Camaro6
Old 11-17-2023, 03:22 PM   #1
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
Exclamation Check your oil filter if you recently had an oil change
Only posting this as it seems to at least one other person is in the same situation as I.
Had my oil changed from the dealership October 02, 2023. Started noticing oil on the driveway and tried figuring out which car it was coming from and posted about it in the member journals
Originally Posted by Bumbleboy92 View Post
No clue where it’s coming from, coolant looks fine and I don’t see any oil residue in the engine bay but the oil spots are still on the driveway so
Last oil change was 10/02/23 from the dealership and only realized now it’s coming from the car as I saw the oil spots after multiple rainy days and thought that’s definitely not right. One of the only times I’m glad for the Ring system (even if it barely works)
Made an appointment at the dealership, preparing myself to be out of a car for a while but hoping not
Originally Posted by m6-lt1 View Post
Found oil underneath my brand new 2023 2 weeks ago. Had taken it in for the 500 mile oil change 3 weeks prior to that. I went underneath the car and noticed the oil filter was very oily. It was tight. Oil was also all over the silver crossbar thing.
Took it back to the dealer a few days later. They said there was a crimp in the oil filter that caused it to leak. Whether that was true idk for sure. But we both got our oil changed in October. Maybe they shipped out a bad batch if yours winds up being the same thing.
Finally went somewhat under the car and looks like it’s the same situation for me
Hopefully it’s just isolated but on the potential possibility that batch of oil filters are at fault, I thought to share
2022 2SS 1LE - Cold Air Inductions Elite Carbon CAI
2016 1LT v6
- Totaled
Happiness: Infinite
Bumbleboy92 is offline   Reply With Quote
Old 11-17-2023, 03:39 PM   #2
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
I bet they most likely just double gasketed the filter. Dealerships suck.
Christian1LE is offline   Reply With Quote
Old 11-17-2023, 03:41 PM   #3
Bumbleboy92
Long hauler
That’s my hope, I’ll be sure to post what they say
2016 1LT v6
- Totaled
Happiness: Infinite
Old 11-17-2023, 03:51 PM   #4
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
Or they tighten the living shit out of them until the gasket is deformed beyond recognition
That happened to my daughters Mazda never had so much trouble removing a filter
CalgaryZL1 is offline   Reply With Quote
Old 11-17-2023, 04:14 PM   #5
Christian1LE
They will just lie to you, they won't ever admit they messed up.
Old 11-17-2023, 04:35 PM   #6
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Drives: Red Hot A10 ZL1 Convertible
Check your oil level, no doubt you've lost a bit.
And ALWAYS check it before driving off the lot after a change (even if the lot is your own driveway).
Gunkk is offline   Reply With Quote
Old 11-17-2023, 05:27 PM   #7
Bumbleboy92
Long hauler
Interestingly it’s sitting right at half on the dipstick even with the amount that leaked out. Seems it only leaks when the cars sitting for a while. I am curious as to why it didn’t leak for a month and then it’s dripping more and more oil only after the first month
2016 1LT v6
- Totaled
Happiness: Infinite
Old 11-18-2023, 08:13 AM   #8
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
It maybe a bad batch of AC Delco oil filters especially the rubber gaskets on the filter. Back in the 80s when I had a 1982 Z28 and a 1987 IROC Z28 I would go to the local dealership to buy oil filters because I changed the oil myself and over time had probably 6 bad filters that leaked. The filter itself was good but the gasket was cut uneven or wavy looking and didn’t seal against the block. After that experience I started buying good quality aftermarket oil filters and haven’t had any issues with them.
ZL1 Coupe, PDR, Exposed carbon fiber hood insert, My Link with Nav, M6 6 speed and Silver Ice Metallic. Mods done: ceramic window tint, GM Accessories Camaro floor mats and Roto-Fab CAI.
LT4Greg is offline   Reply With Quote
Old 11-18-2023, 08:27 AM   #9
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
Yep, I actually learned this a LONG time ago while dealing with an old Ford work van. Told my boss about it and he was perplexed how a very tight filter would leak.
2022 Camaro LT1 A10 - Drag Pack/AxleBack -11.849@118.67MPH/1.798 60'
2001 Camaro SS A4 - HCI/Stall/Bolt-on/Gear/Tune/DR/Diet - 429HP/392TQ - 10.99@123.58MPH/1.584 60'
1998 Camaro Z28 A4 - Bolt-on
1999 Camaro Z28 A4 - Stock
FJB
Dynamical is online now   Reply With Quote
Old 11-18-2023, 09:14 AM   #10
MT-SS1LE
Drives: 2023 SS 1LE Sharkskin
Filter is only supposed to be tightened 3/4 of a turn past contact with the gasket, as indicated right on the PF64 filter itself. You can be sure 99.99% of dealer oil change guys are not following this and tightening the crap out of them. I'd put my money on dealer incompetence rather than some defect on the filter.
ΜΟΛΩΝ ΛΑΒΕ
MT-SS1LE is offline   Reply With Quote
Old 11-18-2023, 01:45 PM   #11
2004YZFR1
Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE
I do as much work as i can myself so I know it will be done right. The dealers seem to not know much about our cars and mess things up.
2004YZFR1 is offline   Reply With Quote
Old 11-18-2023, 02:27 PM   #12
GroundhogSS
GroundhogSS's Avatar
Drives: '17 2SS convertible'20 Yukon Denali
Also check that the filter is tight enough. They sometimes err that way. If loose, it can back off and start leaking.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers
Delivered: 08/15/2016
#TeamBeckyD
GroundhogSS is offline   Reply With Quote
Old 11-18-2023, 07:29 PM   #13
NiickySaz
NiickySaz's Avatar
Drives: 2023 Camaro 1LT V6
Okay so idk what the odds are of this...
My buddy, years ago, had a 96 z28. Bought new at the time. Long story short he had something similar(if I recall correctly) come to find out the threads that you screw the filter on were warped. As if someone was putting the filter on but wobbled the hell out of it while they were screwing it in. This was over 20 years ago but I doubt this is a repeat. Hope not sad to see.
Edit, just called him to bring up this memory. He said his filter that came on the vehicle was somewhat loose but still hanging on to the threads, you couldnt just pull it down an out it still needed to be unscrewed, and he only found out by a rattling noise on startup but did see oil anywhere he parked. He cannot remember if it was before or after his first oil change. But he had his car dropped off at the dealer and they worked out with the bank to get him a another car in the same price range.
NiickySaz is offline   Reply With Quote
Old 11-21-2023, 01:27 PM   #14
haggler
haggler's Avatar
Drives: '23 2SS RSblue 6MT, sold '19 ND2
Ive used many pf64 filters (different and updated part numbers over the years) on diy oil changes for my dad's old equinox before he traded and once for my own Camaro. I seriously doubt it's an issue with the filter, more like the dealership hack who installed it. Either too loose or hulk tight without lubing the gasket.
'23 2SS, 6 speed, NPP, Copper-free brakes, 56V Carbon Flash Rims, Riverside Blue
1LE sway bars
EOS front splitter
5-6-22:1100,
7-19-22: 3000,
8-3-22: TPW 8/15/22,
10-4-22: ETA 10/13/2022
10-15-22 6000
haggler is offline   Reply With Quote
oil filter, oil leak
