Old 05-09-2010, 05:02 PM   #1
mdwj
Drives: 2001, RS Camaro
Exclamation FUEL PUMP issues...
Hey there. Went 1 year without major mecanical problem!! Things unfortunately changed 2 days ago. My 2001 RS (V6, 74K) starts, but then the engine doesnt catch. For having had a Ford a couple years ago and a similar situation, I believe the fuel pump is dead. I had it towed to the shop and waiting on diagnosis and estimation.
2 questions:
- How much does it cost to install a new fuel pump on V6 Camaros ($500+)?
- Should I consider using a "generic" part (pump) if it cut the costs significantly or is that really strongly not recommended?
Im starting to wonder if I really want to keep the car if every year Im gonna have to cover $500+ in extra repairs (plus reg. oil changes, etc.). So if the non-OEM pump could last 20K miles, that would work for me...
Thanks for your help, advice, input. Happy Mother's Day.
mdwj is offline   Reply With Quote
Old 05-09-2010, 07:59 PM   #2
jtragolia
Drives: pontiac grand am
That's what a warranty is for, you won't have to pay anything just take it to the dealer.
jtragolia is offline   Reply With Quote
Old 05-09-2010, 08:23 PM   #3
mdwj
well I bought the car from its 3rd owner early last year. So I doubt there's a warranty I can use on the vehicle. But correct me if Im wrong
Old 05-09-2010, 08:41 PM   #4
brandotron
I am the internets.
brandotron's Avatar
Drives: dangerously
Did you even read the post?
brandotron is offline   Reply With Quote
Old 05-09-2010, 08:44 PM   #5
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
check out the trap door mod on camaroz28.com,, otherwise you need to drop your exhaust system and the rearend to even start to get the fuel tank down,, i dont think you would find any shop to do a fuel pump in a 4th gen for $500
Old 05-10-2010, 07:57 AM   #6
jtragolia
I read the post quickly and assumed it was a 2010 not a 2001 bc it's posted in camaro problems/issues on the 5'th gen forum, not under the other generation part of the forum.
Anybody Spray'n their SS yet - nitrous ? WeeZee Forced Induction - V8 37 12-29-2012 09:56 PM
Fastlane duel fuel pump DFS88 Forced Induction - V8 21 04-22-2010 03:02 PM
Camaro Fuel Pump Solution ProudLS Forced Induction - V8 30 04-02-2010 01:14 PM
What kind of gas are you filling up with in your '10 Camaro? JewelZ 5th Gen Camaro SS LS LT General Discussions 42 08-02-2009 09:31 AM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 05:29 PM
