12-01-2010, 06:44 PM | #1 |
Drives: 2010 Join Date: Sep 2009
Alignment Parts, I want more rear camber and front caster adjustments
other than Pedders eccentric bolts has anyone used something similar or different to achieve what I am looking to do?
12-01-2010, 07:18 PM | #2 | |
Drives: 2010 2SS/RS Join Date: May 2010
http://www.pfadtracing.com/catalog/p...roducts_id/202
LME built LSX427 w/t all Callies internals| AGP 65/65 TT | Holley Sniper Intake | Brodix BR3/LME custom ported | LME custom cam | Pro EFI 112 ECU | ID-1700x | NGK BR7EF | AGP's-Fore Triple Fuel pump | Monster LT1-S Triple | ZL1 3.23 diff, CF driveshaft, ZL1 axles | Hurst Line Lock | MGW Retro Short Throw | Pfadt solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Ground Control camber/caster plates | Accelerated Racing Solutions tuned| God is too good! I don't deserve it, but I sure will accept it!!! |
12-01-2010, 09:06 PM | #3 | |
What is Pfadt using for the rear camber? |
12-02-2010, 06:26 PM | #4 | |
Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
There is more than enough adjustment on the rear OEM bolts to suit the amount of rear camber needed to get the tires to bite appropriately. It is for that reason that we use the OEM adjustment for the rear only. |
12-02-2010, 09:22 PM | #5 |
Suspension Specialist
Drives: 2011 Camaro Join Date: Aug 2010
I respectfully disagree with Pfadt. It is my opinion for opimum handling, the rear camber needs to be 50% of the front camber. When adding drop coils in the front and rear, and putting the front cambers to -1.0, which I feel is optimum for aggressive street, you will not be able to get the rear cambers to -.5 degrees without changing the OE eccentrics. Doing this makes a huge difference in handling. Even with OE height, I have been unsuccessull getting the rears to -.5 degrees in many Camaros.
mike dms |
12-02-2010, 09:50 PM | #6 | |
Not sure if the Pfadt Camber plates would work properly with my KW coilovers in terms of fitting the springs. Did Pfadt test these on other systems on the market? |
12-03-2010, 07:07 AM | #7 |
Drives: 2015 Chevrolet SS Join Date: Jul 2010
Try the Pedders Eccentrics in the rear. I think user "mws444" is using the Pfadt camber plate with the Pedders supercar coilovers.
12-03-2010, 10:49 AM | #8 | |
If your KWs use an OE upper strut mount, then they work with our Caster/Camber plates. It is an all inclusive product with proper adjustment capability for repeatable measurements. We even have versions for 2.5" race springs and Grand-Am spec springs. GM used these on the Camaro SSX with much success! |
Similar Threads | ||||
5th Gen Suspension -- The Book | JusticePete | Suspension / Brakes / Chassis | 151 | 05-07-2015 05:52 PM |
Setting up an IRS/Drivetrain for Drag Racing | Kyle2k | Suspension / Brakes / Chassis | 44 | 06-05-2010 09:17 PM |
Im sure this has been asked before.. But forgive my innocence :) | gmag21 | Suspension / Brakes / Chassis | 23 | 02-21-2010 10:29 PM |
Drag Racing Suspension Kits | Info@PeddersUSA.com | Suspension / Chassis / Brakes | 25 | 02-21-2010 08:48 PM |
Suspension guys out there - lets talk wheel hop | Crowley | Suspension / Brakes / Chassis | 14 | 10-09-2009 12:06 AM |
