07-13-2015, 11:24 AM | #1 |
J.Sick
Drives: 2010 Camaro SS Join Date: Nov 2010
Both power windows inop Need help ASAP
I am trying to drive to AZ today or tomorrow. I know I posted in two sections I am just trying to get on the road ASAP. Thanks
http://www.camaro5.com/forums/showthread.php?t=415877
"J.Sick"
2010 Camaro 2SS |
07-13-2015, 12:18 PM | #2 |
Drives: 2014 2SS/RS Camaro Join Date: Dec 2014
You said your car has been sitting for 3 years? Any chance rodents may have gotten in and chewed the wiring? That's the first thing I would check. If all the fuses are good, try disconnecting the battery for about 5 minutes, then hook it back up and see if that fixes it. Try working the switches, and spray a little WD40 in them. If they've tarnished, you might not be getting a good connection when you try to put the the windows up. It's got to be either a switch, wiring or a computer issue.
2014 2SS/RS, L99, SW LTH w/HF Cats, GMPP Ex. Z/28 CAI, FR41s in PVD Black Chrome, Recaros, Pfadt Sway
377hp, 383tq 12.739@110.44 MPH |
07-13-2015, 12:34 PM | #3 | |
J.Sick
I looked at the wiring from the BCM and found nothing visible. If it was only one window I would dig deeper into the wiring but it is both. Neither door will turn the radio off when opened and neither door will cause the interior lights to come on when opened. I am thinking the is a module somewhere that is bad. would think a fuse would blow first though.
"J.Sick"
2010 Camaro 2SS |
07-13-2015, 01:01 PM | #4 |
I think it's related to your car sitting for 3 years. If your doors aren't turning off the radio, then check the switch that lets the car know the door is open. If one of them is stuck, that could be the problem. Having both windows malfunction is not uncommon. They probably share wiring, and if continuity is lost on one side, then neither will work. Keep in mind, I am unfamiliar with the electrical system in our cars. You really need a wiring diagram, or help from someone with a service manual.
07-13-2015, 01:03 PM | #5 | |
J.Sick
Yes if I had a wiring diagram it would be helpful but after searching the internet I haven't found one. So if someone has on please share.
"J.Sick"
2010 Camaro 2SS |
07-13-2015, 01:08 PM | #6 |
I don't know where it is, or if it even exists. There has to be something that sends an electrical signal when the door is open. Otherwise, the radio wouldn't quit and the interior lights wouldn't come on. Look around, you should be able to find it. Like I said, I've not had a reason to become familiar with our car's wiring. I do have some electrical experience, so I was just hoping to point you in the right direction.
07-13-2015, 01:16 PM | #7 |
Would rather be riding
Drives: No car no more Join Date: Jul 2009
What's your battery voltage, and what hell have you put your electrical system through?
I noticed in your other thread you said sitting for 3 years, jumpstarted it and having problems ever since. That wasn't a good plan.
No dog in this fight anymore.
5th Gen owner 2009-2016. |
07-13-2015, 01:46 PM | #8 |
J.Sick
Well I do have a new battery now. Yes I did jump start it at first. Nothing can change that now.
"J.Sick"
2010 Camaro 2SS |
07-13-2015, 03:39 PM | #9 | |
J.Sick
Thanks for the help Camaro5
"J.Sick"
2010 Camaro 2SS |
07-13-2015, 03:49 PM | #10 |
Drives: 2012 2SS Join Date: Jan 2015
At the factory 3 guys install that entire wiring harness in one minute and ten seconds.
I am useless but surprising fact man! |
07-13-2015, 04:09 PM | #11 |
Good job getting to the source of your problem.
07-13-2015, 04:21 PM | #12 | |
