11-02-2017, 08:26 AM | #1 |
Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
Cleaning Lower Rocker Panels.
Got under my '10 Camaro yesterday during an oil change and noticed a few
things. The underside of my rocker panels is full of road tar and imbedded dirt. You can't see this area unless your many feet away from the car. Does anyone have a simple easy solution to removing tar and cleaning this area? Some of what's shown is simple dirt from a recent rain. Sorry, Don't know why these are upside down- lol.
11-02-2017, 08:50 AM | #2 |
Drives: 2014 Camaro 2SS RS & Ground effects Join Date: Apr 2014
Here you go myold88. I use GooGone and a little elbow grease to get rid of the tar.
Don’t walk in front of me, I may not follow; Don’t walk behind me, I may not lead; Walk beside me, and just be my friend.
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260 |
11-02-2017, 12:09 PM | #3 |
Drives: 2010 Camaro 2SS/RS Black & Silver Join Date: Aug 2010
Clean them with just soap and water first. Use a nylon bug sponge. Then spray WD-40 on to break up the remaining tar and animal guts. Then use soap and water again followed by some wax. May require heavy elbow grease.
STAINLESS WORKS HEADERS-TUNED BY JANNETTY RACING-C.A.I. INTAKE-TAYLOR 409 WIRES-SOLO AXLE BACK EXHAUST-ELITE CATCH CAN |
11-02-2017, 01:02 PM | #4 |
Drives: 2011 ss Join Date: Sep 2015
I think jus1dab has a good suggestion.
Just make sure to use a good quality dish soap like dawn and all the wd40 residue washes right away |
11-02-2017, 01:37 PM | #5 |
Thanks guys. My WD40 and Dawn are 6 feet from my Camaro but where do you get GooGone
and a nylon bug sponge? WalMart or Auto store I'm guessing Going outside right now to try the WD40. It's 70+ degrees here in Ct today and tomorrow.
11-02-2017, 01:45 PM | #6 |
If your using wd40 I don't think you'll need goo gone. Most basic sponges are either identical on all sides or soft on one side and have a net looking opposite side for bugs. I really only use that side for the barrel of my wheels but that's a good application in your case.
11-02-2017, 02:04 PM | #7 |
Walmart sells it in the hardware section as well as the auto section.
11-02-2017, 02:14 PM | #8 |
Ok, I just went outside and applied WD40 and let it sit, then scrubbed it with a cotton cloth
for a few minutes (from the door edge forward). Within 5 minutes it look like this. My old WD40 can jammed up so I only got a small amount onto the car. Amazing stuff. Also I never realized that there's a plastic chip guard there also. It's faded and yellow from 8 years & 50,000 miles of use so I doubt that will ever clean up. Another nice day tomorrow so off to Walmart AM and I'll finish up at least one side. Stewart I need your help again- lol Sorry, Crooked photo again, Don't know what's up with that. Never happened here before. |
11-02-2017, 02:21 PM | #9 |
Glad it all worked out for you.
11-02-2017, 03:04 PM | #10 |
11-02-2017, 10:00 PM | #11 |
WD-40 #1. I also do my rims with it. Adds a nice protection layer so each time I clean the rims the dust, dirt and break dust slip right off with an easy wipe. I recommend the non aerosol spray as it's less messy. I buy the gallon can and pour into a spray bottle. I find it less messy this way as it doesn't mist everything other than what I want it on or I just spray a rag and wipe down whatever I'm cleaning.
Car mods: never enough!
11-03-2017, 08:06 AM | #12 |
Banned
Drives: Camaro Join Date: Mar 2013
11-03-2017, 11:17 AM | #13 |
Drives: Camaro V6 Join Date: Oct 2016
Some small rock/mud guards would eliminate most of that.
11-04-2017, 01:14 PM | #14 |
My Camaro is pretty much chip free after 8 years so I think those stone guards may just be one more thing to clean.
I've got one chip on my hood, some gouge type cuts on the front facia, and absolutely none on the 1/4 panel gills. Go figure?
