05-26-2014, 08:51 AM | #1 |
Amanda
Sub doesn't work unless car is running
Is this normal? We just got a sub installed and while the car is running, it's on. Once you turn off the engine and keep the stereo on, the sub shuts off. Is something wired wrong?
05-26-2014, 08:57 AM | #2 |
LEXi is Sassy and Classy
Drives: 2012 Camaro 2LT RS Boston Acoustic Join Date: Mar 2014
Not enough power to drive your sub or a wiring issue.
05-26-2014, 09:38 AM | #3 |
Drives: 2013 Ray Blue 2SS/RS Join Date: Feb 2014
Sounds like the remote wire on the amp may be connected to something that's only on when the engine is running. When you turn the engine off do the lights on the amp turn off? If so it's probably that's probably your problem.
Sent from my Nexus 7 using Tapatalk
"Be so good they can't ignore you" |
05-26-2014, 09:44 AM | #4 |
Drives: 2010 Chevy Camaro 1SS RS Join Date: May 2014
Probably something with the remote wire would be my guess.
05-27-2014, 01:38 AM | #5 |
Drives: 2014 2SS RS Coupe Join Date: Aug 2013
I'm assuming when they wired up the stereo they hooked the remote wire up to the 12v power source like the cigarette lighter, if this is what they did then it makes sense that it stops when the car is off, all you need to do is re-position the remote wire for the amplifier. Very easily done, you should tap it into a wire on the head unit.
05-27-2014, 01:43 AM | #6 |
Drives: '11 SW 1LT RS Join Date: Aug 2012
On the bright side you will never run down your car battery!
