08-03-2014, 02:02 AM | #1 |
Unable to auto pump gas!
I have about 1200 miles on my 2SS. Even though I just made 5-6 trips to the pump, I'm exhausted as I'm unable to pump gas automatically.. By pressing the handle. And if I hold it manually in a certain angle it seems to work. Any known issues? I tried to look online but didn't find any recent posts on this issue. I usually pump at Kroger or SAMs club as it saves me money, tried at a chevron but same issue everywhere. Appreciate any input.
Thanks Nash. |
08-03-2014, 02:18 AM | #2 |
Drives: '04 Z06, '14BMW M235i, '15 SS/1LE Join Date: Feb 2014
Strange, like the pump would shut off like you have a full tank?
08-03-2014, 02:19 AM | #3 |
SHKE BKE
Drives: 2013 Camaro Join Date: May 2014
I've always had this problem at certain pumps
08-03-2014, 02:37 AM | #4 |
iv never had this problem. remember though after it shuts off dont fill it more.
08-03-2014, 02:49 AM | #5 | |
Drives: 2011 Camaro ss Join Date: Apr 2014
08-03-2014, 02:55 AM | #6 |
Drives: 2014 1SS/RS, 2018 Silverado CC Join Date: Apr 2014
Haven't had this problem with my camaro, but I have it with my truck. Maybe something to do with the pumps because I usually fill up at the same station and I'll have the issue during a fill up and won't have it on the next.
08-03-2014, 04:07 AM | #7 |
ROAD COURSE JUNKIE
My 2010 Camaro wouldn't let me auto pump but my 2012 does. Not sure what the difference is.
08-03-2014, 04:28 AM | #8 |
Same problem here.
08-03-2014, 04:37 AM | #9 |
Drives: Hyper Blue 2SS Join Date: Jun 2013
That's crazy! So you can not pump gas without holding the trigger? I know the gas door is cheap but seriously?
08-03-2014, 06:58 AM | #10 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
Usually need to pick up on the handle to allow the nozzle to have more of a straight shot down the gas filler tube. The pump shuts off if I just leave it hang with the lever locked. It usually dispenses fine if the lever is not in the maximum position. So maybe try a notch or two lower on the lever. Of couse it will take more time, but it won't be exhaustive for you.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
08-03-2014, 07:47 AM | #11 |
Yes. That's the issue, glad that I'm not the only one..I was trying to put it on mid level on the handle but seems like there's a vacuum that's being created. Do u guys think a trip to the dealership helps?
08-03-2014, 07:59 AM | #12 |
Drives: 2014 1SS/RS LS3 Join Date: Jul 2012
I had this problem in my truck. It was the EVAP vent valve solenoid. It did not allow air to escape the tank properly so the only way it could get out was back up the filler neck causing gas to backup a bit and click the pump off. Not sure if its a similar system in the camaros or not but it was an easy fix on the truck.
2014 1SS/RS LS3 AGP TT, Custom TSP Cam, 4L80E Swap 1/4 mile- 9.53 @ 145mph
08-03-2014, 08:02 AM | #13 |
Drives: 2013 Victory Red ZL1 Join Date: Jan 2013
It may be the type of vapor recovery system used by the station. I would experiment with several other stations and see how theirs work. It could also be that the stations VRS needs maintenance.
08-03-2014, 08:25 AM | #14 |
Drives: 2011 Camaro 2SS/RS LS3 Join Date: Aug 2013
I changed oil in HS at a small shop/gas station back in 99-01 and saw so many people set the pump to "auto" then have it shut off on them too early or fly out of the neck and blow gas all over their car etc. that I never used the auto pump feature. I actually think some states dont even allow the pumps to have that little metal clip so they force you to hold it yourself.
this sounds like a silly problem lol
2015 Silverado Z71 6.2/2011 Camaro 2SSRS LS3/2014 Cadillac ATS 2.0T
Tags |
fuel pump handle |
