11-02-2010, 09:23 PM | #1 |
ZL 1 3 7
Drives: '23 ZL1 Join Date: Apr 2010
First Uh-oh...
Hey guys,
So today I pulled my camaro out of the garage, and noticed two small spots on the garage floor Front passenger side, mid-hood area, and it looks like oil... I touched the spot, smelled it, and rubbed it between my fingers (what little I could pick up on my fingers, the spots are 2"x2") and it seems to be oil, but I checked it and it is untouched... the level is fine. It has been 807mi since my last oil change (5800mi total)... Im going to have it looked at tomorrow, but if anyone has any info or speculation I would appreciate it in advance so as to give the dealer a heads up...
'11 2SS / '23 ZL1 / '23 Silverado ZR2 Daily
11-02-2010, 09:25 PM | #2 |
Next is SS camaro.....
Drives: 2010 Camaro LS, Rally yellow Join Date: Feb 2010
Uh oh indeed.
Airraid CAI, Havoc Rims, Perreli tires, Remote start
11-02-2010, 09:26 PM | #3 | |
I used to be Dragoneye...
But the dealer can do that and tell you exactly what's wrong. There are many gaskets and seals on the engine...it could be anything. |
11-02-2010, 09:33 PM | #4 |
maybe some one did a prank on you
11-02-2010, 09:37 PM | #5 |
Drives: 2011 2SS Join Date: Jun 2010
poor design. If it is the oil pan gasket, you almost have to pull the motor to replace it. the cross member is not removable which is retarded.
11-02-2010, 09:37 PM | #6 |
Drives: 2010 2SS/RS RJT Join Date: Jun 2010
If possible you need to get under car (safely) and see if you can see origin of 'unknown' fluid. No offense,but if you can't identify the type of fluid a trusted mechanic/knowledgeable friend is your only option before dealer. Obviously there are many possibilities-hope yours is a very simple/minor one.
11-03-2010, 01:48 AM | #7 |
Drives: 2010 Rally Yellow 2SS RS Join Date: Oct 2010
Could be beetle juice?
11-03-2010, 04:58 AM | #8 |
ride the pain train
Drives: 2011 1LT RS, 1998 fxstc HD Join Date: Jun 2010
Maybe when you filled it you spilled some? Maybe didn't tighten the cap on the filter?
PAIN is temporary, PRIDE is forever......RACE HARD
11-03-2010, 08:10 AM | #9 |
Drives: abm2ssrs Join Date: Apr 2009
check oil pan and oil cooler .
[SIGPIC]
11-03-2010, 02:34 PM | #10 |
ZL 1 3 7
Took it to the dealer today, and it was power steering fluid! They ordered me a new hose, and temporarily cut and clamped the existing one... The new hose is coming from michigan, so I wont be driving my Camaro on a cut&clamp for 5 days...
oh well, it goes into storage as soon as its fixed anyway!
11-05-2010, 09:09 PM | #11 | |
[SIGPIC]
11-05-2010, 09:41 PM | #12 |
ZL 1 3 7
Just glad it wasn't major
11-06-2010, 06:01 AM | #13 | |
Drives: 2010 supercharged LS3 Join Date: Jan 2010
so u had a hole in a power steering line??? I had a leaky pump....and so have other people....I'd keep an eye on it |
11-06-2010, 03:02 PM | #14 |
ZL 1 3 7
Will do... Thanks for the heads up
